What does an AC/DC cast base mean?
  • ryan.s
    • 785
    • So Cal
    There are several different Milwaukee chop saws on amazon and one particular model says it has an AC/DC cast base. This is the same one that HD carries. What does it mean and what are the benefits if anything?
    http://www.amazon.com/Milwaukee-Cut-...4182373&sr=1-4
  • DJehlik
    • 49
    • Walnut Creek, CA
    • Ryobi BT3100-1
    A link to the Milwaukee site:
    http://www.milwaukeeconnect.com/weba...oductId=684432
    The "AC/DC" means it will run on either Alternating or Direct Current as long as the supply voltage and current capacity is correct. The motor is probably a "Universal" motor that has brushes, instead of being an induction motor.
    The "Cast Base" part indicates that the base of the unit is cast material, in this case, cast iron.
    • scorrpio
      • 1566
      • Wayne, NJ, USA.
      Heavy Metal!!! AC/DC approved. Let there be Rock!
        Commas are wonderful inventions. misplaced ones can lead to trouble.
        A panda bear walks in to a convenience store. Attendant asks what he needs. The panda points to the sandwiches, the man gives the bear the sandwich which the bear consumes. Then the bear pulls out a pistol and fires, fatally wounding the attendant and walks out the door. As the bear exits, the man asks with his dying breath, "Why?" The bear shrugs and tosses down a textbook open to the page on panda bears. It says: Panda Bear - endangered species. Native to China. Eats shoots, and leaves.
          Good one, Loring.
            Originally posted by JR
            Good one, Loring.
            I have to confess this is from Lynne Truss' best seller book, which I read, but the best thing about it was the opening story, so if you read my post you don't need to buy this book.
