Question for 22124 owners
  • hermit
    • 379
    • Somerset, PA, USA.
    I just recently got the Craftsman 22124 TS and have some vibration that I think is actually normal, but figured I'd check with others. The saw runs smooth, and cuts great, but when I power it down, I get a little vibration as the motor slows down. My shop is in the second floor of my garage and the floor is supported by trusses. I think thats why I notice this, since I'm not on concrete. Opinions?
    thanks,
    Todd
  • Tarheel
    • 114
    • N. Carolina
    I have the same saw. It is as smooth as silk on startup and while running/sawing. When I power it down, there is a slight "clunking noise" as the blade spins down to rest. I have a close friend with the same saw and the same shutdown noise. I just assumed it was the motor/belt winding down. Definitely has not been an issue with smoothness while running though. (Mine did pass the "nickel test" when I first set up the saw.
    Wayne
      its probably a phenomena known as resonance.
      Every mechanical thing has a frequency thta it resonates at. When a little bit of energy at that frequency hits it, it exaggerates the amplitude greatly. Much as humming the right note can make a glass vibrate.
      When the saw spins down it is changing frequency, eventually it hits the resonance of the saw and it vibrates some more.
      That's normal as no blade/motor is balanced perfectly and always vibrates just a little. the resosnance amplifies that.
      As long as the saw does not resonate at the operating RPM, you're ok
      • dgcoles
        • 11
        I have the same saw. As has already been stated I don't think you have anything to worry about. The first time I powered it down I was worried. I turned it on and off several more times and thought there must be a problem. Went inside to surf the net for an answer and got some reassurance this was normal. Oddly enough the next time I used the saw it wasn't as bad and has gradually got better to a certain point. Enjoy the saw, you will love it
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          Mine does pretty much what the others have stated. Runs smooth, shimmies a little upon slow down.
          • hermit
            • 379
            Great! Thanks a lot. It "seemed normal" to me but thought I'd double check. Now I can sleep at night. Funny thing, I used it today briefly, and it doesn't seem as bad as thought after all. Maybe it is "breaking in".
            thanks all,
            Todd
            • jarhead
              • 695
              • Boynton Beach, FL.
              Todd,
              My 22124 exhibits exactly the same behavior.
