Miter gauge
  • jussi
    • 2162
    Miter gauge
    Looking for a miter gauge for a used TS I got that didn't have one. Price range is somewhere close to $100. any suggestions?
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    Incra V27 (add your own fence) - ~ $60
    http://www.epinions.com/content_195368423044
    Alot of people like the Incra 1000SE....it's similar to the V27 with it's own fence. I haven't used one personally though. Goes on sale near $100.
    The Woodhaven basic is ~$60. It only does 45/90d but is incredibly well built, accurate, and simple. Needs a fence too.
    • MilDoc
      Incra. 'nuff said.
      • jussi
        • 2162
        I was looking at the 1000se. A little more than my budget ($150) but I wouldn't mind too much if it came with a good fence. How much more would a fence cost if I got the V27? Is the fence on the 1000se worth the extra $90 or would I be better off buying a different one?
          • 8797
          Woodhavens is a little more than you asked for - $122.99
          http://www.woodhaven.com/detail.aspx?ID=1641
          The one advantage that it has over the Incra is its ability to swing 180 degrees for a much wider angle variance, versus 120 (I think) for the Incra.
          • Knottscott
            • 3815
            • Rochester, NY.
            A fence could cost as little as a piece of scrap wood. I added a Hartville fence to mine for ~ $30.
            • RodKirby
              • 3136
              • Mao Shan TSC-10RAS
              What Hank said...
              Downunder ... 1" = 25.4mm
              • hermit
                • 379
                • Somerset, PA, USA.
                Dustmite:
                I see you have the Craftsman 22124. It looks like you moved your fence rail to the right a little. Is that right? I was thinking of doing something like that to increase from 30" rip capacity without buying a new rail. Any details would be appreciated.
                Thanks Todd
                • softop41
                  • 470
                  • Plainfield, IL, USA.
                  MilDoc said it ALL!
                  Jerry
                    I have the V27, I like it, but if I were to buy again, I'd go for the new version of the 1000se. It wasn't out when I bought mine. They now have it with a nicer fence and stop.
                    • jussi
                      • 2162
                      So you think the fence is worth it instead of getting the v27 and a cheaper fence?
                        Incra V27 or 1000SE. The V27 works fine with a shop made fence. You can use a piece of scrap and a spring clamp as a stop block.
                          Hank, what's the purpose of a miter guage going to 180 degrees? It's early!
                          Thanks Hank.
                            • 8797
                            Thanks Hank.
                            Hey Ken, Don't ask questions like that. I don't really have an answer other than it just looks cool!
                            Seriously, We generally think of a long taper jig to run along the rip fence for making tapers on anything longer than 18 inches, but the 180° miter guage with a fence and stop at the back will make great tapers on shorter narrow pieces. I had to cut a spacer to get the the width correct but did fine for some short pieces. I made several (12 inch) taper pieces about 4 years ago on the BT.
                            Beyond that, I don't have an Incra miter guage but have handled them. They sure look cool but for me, they just don't have the "feel" of durability like the Woodhaven miter has.
                            • RayintheUK
                              • 1792
                              That's what made up my mind too when I bought my Woodhaven. Great gauge!
                              Ray.
                              Did I offend you? Click here.
