I know that cold weather is tough on combustion engines, but how about electric motors? I fired up my 220 V 3hp planer today and it was very slow getting up to speed. The shop is not heated and was probably around freezing. I have a 100 amp panel in the shop. Only thing on was 220 V 3hp DC pulling about 18 A. Does cold weather affect machines? Will it damage them?
Weather And Motors
Tags: None
My guess is it was more the lube and the belt than the motor. I worked in the steel industry and saw motors out in the elements all the time with no ill effects.John Hunter -
probably lubrication (gets thick when cold) in the bearings and the belt was probably very stiff.
Cool. The 15" planers do have a lot of gear oil in them so that with the belt stiffening makes sense. I didn't know if there was possible metal contraction or some thing like that.
ThanksComment
If the gear oil is 90 weight, it would be thick like syrup til it warms up.No good deed goes unpunishedComment
LCHIEN
