HF 43430 hvlp?
  • scoly
    • Jun 2003
    • 395
    • Lubbock, Texas, USA.
    HF 43430 hvlp?
    Tried searching but no luck.
    In the past I have seen discussion on a tip for the 43430 that would help with spraying latex. Anyone know what it is and where to get it?
    Thanks
    Steve
    It\'s the combined experience of the members on this board that make it such a great place.
    Thanks
    Steve
    try searching for 43430 alone or
    43430 latex
    I got a bunch of hits that looked like the correct answers mightbe there.
    • MBG
      • Apr 2003
      • 945
      • Chicago, Illinois.
      Go here:
      http://www.amazon.com/Porter-Cable-P...7?ie=UTF8&s=hi
      Look at the third review. I bought this tip and it works great. Only problem is that you may need to re-position the brass ring that is press fit on the needle - I did. The ring controls the closed position of the needle - mine didn't fully colse at first. I used a propane torch to heat and move the ring.
      Also, don't be surprised if the tip costs more than the HF gun. I actually bought two of the HF guns - one for latex and the other for finishes.
      Mike (If you can't find the info let me know)
      • radhak
        • 3061
        • Miramar, FL
        • Right Tilt 3HP Unisaw
        dunno what that zip code you mentioned is for ( ) , but the best tip for Latex paint on HVLP is to use 'Floetrol' Paint Additive. you get it in HD. google it for more.
        - Aristotle
        • scoly
          • Jun 2003
          • 395
          Thanks! Will check it all out.
          Steve
