Air Wrench / Impact Driver for Lawn Mower Blade Removal?
  • Uncle Hook
    • 314
    I am looking for some advice on selecting a tool to make it easy to remove a lawn mover blade. As I have gotten older, my strength is not what it used to be and I struggle remove the blade when the bolt is put on too tight.
    I recently purchased a 1/4" Milwaulkee Impact driver which is just great for driving screws & bolts. Big imporvement over a cordless drill. I like the torque this tool provides, but I am not sure how well it will work for removing the lawn mower blade.
    I am wondering if an air wrench like this would be a better tool.
    http://www.harborfreight.com/cpi/cta...emnumber=47214
    I like the shape of this tool for getting under the lawn mover without having to turn the mover on its side. Will an air wrench like this provide sufficent torque to remove the bolt? I have never used an air wrench.
    Or do I really need an air powered torque wrench - somethng like this?
    http://www.harborfreight.com/cpi/cta...emnumber=53176
    What do you use / what would you recommend?
  • SheriffPopeCo
    • 16
    • Golconda, Illinois, USA.
    My advise. Look around find a impact tool 1/2" or larger
    that has 600ft lbs of torque. This would probably be able
    to take lug nut off a car also. The little torque wrench
    has only 50-60 ftlbs of torque. I use mine the same way
    you want(lawn mower blades etc..).
    • TheRic
      • Jun 2004
      • 1912
      • West Central Ohio
      Save your money!!! Use the impact driver you already have. Check out the spec's, I'll be willing to bet it has more than enough torque to do the job. It might even have enough to torque the head off the bolt. At the very least try it first!!!
      Ric
        • 22023
        the air wrench will just end up spinning the blade and motor around.
        You need an impact tool or you will have to supply the manual counter-torque to the blade and motor.
        The impact tools will pop the bolt with short rapid bursts of energy that will let the inertia of the blade and motor keep it from turning.
        I don't think the bolts on the lawnmower are that big (can use with 3/8" socket sets), probably your electric impact driver will work if you have socket adapters for it. Try it anyway.
        I don't think you need to torque the bolt excessively when putting it back on, it has a hub that engages the blade to keep it from spinning and the bolt should have a lock washer IIRC (been a while - I have someone doing my lawn now).
        • onedash
          • Mar 2005
          • 1013
          • Craftsman 22124
          my craftsman air rachet works great for stuff like that. It still turns in tiny increments like an impact gun so stuff that normally requires brute force to hold still (like a lawnmower blade) when you use a wrench you dont any more. So almost any time I need to remove a bolt like that thats what I grab. Wheels on a grinder is another one its great for.
            Is the problem the typical one, where the blade wants to turn why you are trying to loosen the bolt?
            If so, just go to Lowes.com and search Item # 188341
            Model # BB-100 blade buster. I use that and a either a breaker bar, or one of my 1/2" flex head ratchets. Since they saw me using it at the garage, I always get asked if it can be borrowed.
            Not sure if this will take directly to it if Lowes allows:
            http://www.lowes.com/lowes/lkn?actio...100&lpage=none
            Air ratchets, typically still need the bolt broke loose, and if you have to turn it over enough for an impact wrench, you might as well turn it over.
            • Tom Slick
              • 2913
              • Paso Robles, Calif, USA.
              • sears BT3 clone
              as has already been mentioned; I'd give your cordless a try, they can be amazingly strong. air rachets have very little torque.
                • 4715
                Along with many other tools I have a 3/8" dr Blue Point air ratchet. Blue Point is a Snap-On value brand. For breaking fasteners loose it is next to worthless if any torque is needed, the same is true of tightening. To remove my John Deere's blades I use ] this ratchet 15" 1/2" dr which gives me plenty of leverage. Before I replace the blade bolts I coat them with anti-sieze which seems to keep them from becoming too hard to remove.
                • Uncle Hook
                  • 314
                  I checked the specs and I was surprized to learn that my little Milwaulkee 1/4" Impact Driver has a Torque rating of 740 in.-lbs. I thought the tool would be unsized / underpowered for the job, but I going to give it a try before I do anything else.
                  Thanks to everyone for their ideas and suggestions.
                    In the past I've had problems with powered tools torqueing the heads or rounding off bolts/screws etc. I prefer to back out stuck bolts the old-fashioned way - a longer handle on my wrenches. that way I can feel if it is not moving like it should.
                    • Perfidiajoe
                      • 1170
                      • Copiague, New York, USA.
                      As someone who has done this many hundred times, take my advise. First & I can not say this enough REMOVE, & GROUND the spark plug wire. Next wedge a 2x4 between the blade & frame, so the blade can't turn. Then with 1/2" drive breaker bar, & socket, With a piece of pipe for an extention if needed, remove nut or bolt. No or little expense this way. If you would like a new tool get the impact wrench for this, you can also use it for tires on your car. Air ratchet, though a good & useful tool is not for this. The last thing you want is to have a loose blade on a lawn mower, after reinstall. Even if you do get the impact gun follow the steps I gave you to prevent accidently starting the engine in either direction. Good Luck, Joe
                      It's got to be us, because there are a lot more of them!
                      • Cheeky
                        • 862
                        • westchester cty, new york
                        • Ridgid TS2400LS
                        I've come up with something in my days working in a bicycle shop to extend the leverage of a regular ratchet.
                        I put an old, yet straight, handlebar on the handle of the ratchet, and bolts come loose without any problems whatsoever.
                        Give it a shot, I can guarantee it will work and you'll save a hundred bucks or so.
                        You can go to a bike shop, and they will probably have old bars around for free if you ask nicely.
                        If you do decide to go with the impact wrench, pay heed to the power and make sure your grip is secure.....they can snap your wrist in an instant.
                        Pete
                        • Perfidiajoe
                          • 1170
                          Not to be disrespectful, but you shouldn't put extentions on a ratchet, as all the presure is on the ratchet pawl, & you may get away with doing it that way but if it skips you break the ratchet & possibly get hurt. IMHO, Joe
                            That's why I still buy Craftsman hand tools. No questions asked and there is always nearby if a tool fails. Normally will use a breaker bar for this but there are times when you can't get enoug 'swing' and have to go with a ratchet.
                            I have the metal handle from an old mop wringer in my tool box for when I need a bit more leverage. There is also an old MC fork tube in the corner when some major grunt is needed! Try breaking loose bolts on the frame of a 42 year old truck.
                            • Perfidiajoe
                              • 1170
                              Who cares about the ratchet, but I've grown attached to my hands. & I break them loose on earth movers
