Step Drills
  • jarhead
    • 695
    • Boynton Beach, FL.
    Step Drills
    Does anyone own a set of these step drills? It seems that for each size hole, you can only drill about 1/4" deep until you hit the next size.
    They're not for drilling deep holes, drilling in 1 x wood would be impractical.
    In my experience these are great for drilling clean holes in sheet metal or thin plastics, etc that would be dented and deformed by using a large drill bit.
    • Tequila
      • 684
      • King of Prussia, PA, USA.
      I own a couple of similar ones. They're meant for cutting metal (plates, angle iron, etc), so you usually aren't working with anything more than 1/4" or so thick.
      And they are absolutely fantastic for cutting metal - they cut much cleaner than standard twist bits without any of the deformation or tearing that sometimes happens at the end of the cut.
      -Joe
      • eezlock
        • 997
        • Charlotte,N.C.
        step drills......
        I have that same set from HF paid $9.95 I think a while back. Like previous poster said, they work better on metal and plastic. Great for enlarging holes
        that you may need a little more clearance on, for making things easier to adjust as needed. eezlock
        • Hellrazor
          • 2091
          • Abyss, PA
          • Ridgid R4512
          Those bits are made for drilling into metal.
            I'm sure they would drill quite well in wood, but of course the problem is that if the wood is thicker than the step heights then you'll get a stepped hole. So, it would be good fro drilling holes in veneer or balsa or other thin sheets of wood.
            The step heights are probably like 1/8" or so, so that basically limits the step drills to 1/8" thick materials or less.
            • eezlock
              • 997
              • Charlotte,N.C.
              step drills...
              in wood, they wood make stepped holes...hey what about using them for countersinking? ....not too deep though.just a thought. eezlock
              • sacherjj
                • 813
                • Indianapolis, IN, USA.
                For countersinking, I use the 3 bit Dewalt set for #6, #8, and #10 screws. It was around $20, but I use it all the time. It makes life nice, when doing a bunch of wood screw joinery.
                Joe Sacher
