I bought the HF Dovetail jig the other day for $29.99, and have to say the "value" is questionable at best. As has been observed in previous posts, the instructions are near useless, the cast aluminum template is rough enough to slice your fingers on if not careful, and, on mine, one of the bolts for the pin board hold-down is bent about 10* and won't tighten down very far. The advertised 1 1/4" maximum stock thickness is a joke. With the template fully-extended, the fingers barely reach the edge of a 3/4" tail board.
I saw where some folks have bought the Rockler templates to replace the awful stock template on this jig. So there you've tacked on another $15 to this "value" jig. Then, if you don't already have them, $10 - $20 for a dovetail bit and another couple of bucks for a 7/16" template guide bushing. Factor in just the jig, bit, & bushing, and you're up to the $49.95 cost of the MLCS DT jig, which comes with everything and is probably much better quality.
Starting over again, that's the route I'd go (may still).
