I have a new HF Framing nailer and I need your help about what size nails to shoot. When framing a wall I plan to shoot 3 1/2" nails though the baseplate/top plate and into the vertical stud. But why size nails to you use to join two pieces of 2x material on the flat side? 2 1/2" or 3" nails? Will 3" nails be overkill and blowout the other side?
What size nails?
Sorry - I was thinking 1x material, not 2x.
I deleted my answer, it was completely wrong.
better explaination
I must not have explained myself very well. I know Loring is not suggesting I frame walls of 2x4 with glue and brads. I am framing some walls for a closet and bathroom using standard 2x4. I know at some point I am going to be forced to join two pieces of 2x4 throught the small dimensions. Meaning 1 1/2" against 1 1/2", for a total of 3". What is the standard framing practice in this situation? Previously I have only framed using a hammer and 10d, 12d etc. So do I shoot 3" nails and possibly have the tip sticking out the back? This would have the most nail in the wood. Not quite the 2/3 rule, but more than a 2 1/2" nail. Framers may not handle this situation a lot and might just shoot 3 1/2 all the time. But is has to happen. In my case I know I have to tie some rafters together with 2x4 to form the ceiling of the space I am working on. The rafters 2x4 already, so I don't get a choice what I am nailing into.Comment
In my post I answered your question. You asked if a 3" nail was too much for two 2x4's flat. Two 2x4's equal 3". That's a 3" combo, which is short for combination, not a take out burger. Use a 2 1/2".
"I'M NEVER WRONG - BUT I'M NOT ALWAYS RIGHT"Comment
BOCA (Florida) which is different then the rest of the USA states that for 2x4 nailed on the flat to another one that a 2.5" is required minimally
To me that means you COULD shoot a 3" on an angle (which is what we do when we shoot with a gun) to insure that it doesn't punch through
It goes further to talk about cement or glue coating but that wasn't asked
Dr DaveNewest site to learn woodworking, DIY and Home Renovation.
www.onlineshopclass.com built by woodworkers for woodworkers and supported by the industry so everyone wins
If you are in the Orlando area contact me lets get together and talk saw dust (or food or anything else you like except sports)
My wife and I are National Food Judges so we CAN talk food with the best.
Dr DaveComment
I don't switch nails while framing. The only switch I make is to 8d galv ringshanks for sheathing. If you are framing a wall that is going to be enclosed on both sides, who is going to notice a few nails that poked through?Comment
Any more experience?
"I don't switch nails while framing. "
Mike, You don't switch. Does that you mean you use 3" nails everywhere? What about through the base plate in to a vertical stud? Shouldn't I use 3 1/2"? Speed is not the issue here. So I don't mind taking the time to switch. I am about to buy a couple of boxes of nails and I want to know the sizes I am going to need most. And you are right, the places where a 3" nail will poke through, will be covered by drywall. - KevinComment
We only use 3" except sheathing and roofing (and of course that is a different gun). We even use 3" in sheathing if we are too lazy to swap the sticks or the guns
We use 2" for sheathing and 3" for everything else
Dr DaveComment
LCHIEN
