Routing End Grain
  • Rand
    • 492
    • Vancouver, WA, USA.
    Routing End Grain
    I am an inexperienced router user. The other day while attempting to make an oval picture frame out of red oak I had some pretty bad tear out problems on the end grain.
    I was using a 1/2" roundover bit with an old Ryobi router mounted in the bt's accessory table. It worked fine until I get to the end grain of the piece then it grabs a big chunk of wood and ruins the piece while trying to throw it out of my hand.
    So far I have tried the following:
    Taking very small bites by making multiple passes and raising the blade slightly each pass.
    Routing the end grain with the direction of the blade. That works better than against but still not perfect.
    Using a lot of pressure - pushing the piece hard against the bits guide bearing and hard against the table.
    These techniques made things better but I still had a little tearout. I googled it and the only thing I found was wetting the wood. I haven't tried that yet.
    Anybody have any advice?
    Rand
    • 22108
    Well, that happens to us all. Things you can do:
    1) for safety's sake use a pivot pin, this is described elsewhere it will prevent that wanting to thorow the piece at the end!!! Please do it!
    2) route the end grain ends first (if you are routing all four sides, then the chipout will be in the side which will more than liekley get routed off when you do the sides.
    3) Use a backup block of scrap wood to support the end of the wood as it comes off. E.g. the backup wood should be flush with the workpiece in the routing direction but be an extension of the wood in that that direction. Then the chipout will be at the end of the scrap piece and not the good piece. This is the best way.
    • Thom2
      • 1786
      • Stevens, PA, USA.
      • Craftsman 22124
      psssst .... hey Loring .....
      Originally posted by Rand
      The other day while attempting to make an oval picture frame out of red oak ...
      Red oak is notorious for blowout/chipout, what I've found to work for me on curved pieces is VERY light passes with the roundover with the final pass being a very light climb cut pass (I don't reccommend climb cutting to anyone that doesn't fully understand the inherent dangers of the procedure)
      I do agree with Loring that a starting pin is a MUST, especially on curved work and making climb cuts, the pin gives you something to leverage against and GREATLY improves your control, I can't stress enough the use of a pin when freehand table routing.
        • 22108
        Quote:
        well, duh, sorry, I guess i read it too fast and that was one of those, "Oh, I know what's wrong" reactions.
        Yeah, Thom's got the right answer for the reverse grain on a curve chiput problem. Hate that when it happens.
        • Rand
          • 492
          I'm using the accessory table on the BT3000 which doesn't have a starting pin or anywhere to put one without drilling and tapping etc.
          Thanks for the advice guys. I guess it's time to get something other than read oak and a real router table or shaper.
          Rand
          • Thom2
            • 1786
            • Stevens, PA, USA.
            • Craftsman 22124
            I'm using the same setup, I just drilled and tapped a 1/4"-20 hole in the table, then for my pin I cut off a 1/4"-20x2" bolt so that it had about 3/8"-1/2" of threads and 1" or so of smooth shank.
            • TomM
              • May 2006
              • 5
              • Houston, TX
              • Craftsman
              Perhaps the bit is dull, or of low quality. Take shallow passes, and should probably keep the rpm's rather high (if variable speed router), but not so high that it burns the wood.
                One other tip, wet the fibers a little. It should make them "stand up" a little, which will allow for an easier cut.
                • Howard
                  • 176
                  • Plano, Tx.
                  • Laguna Platinum Series - sold my BT!
                  Can someone explain to me the concept of the pivot pin? I'm also new to routing and don't want to compromise safety. Where are the other posts about it?
                  Howard, the Plano BT3'r.
                  Confucious say, "Man who get too big for britches will be exposed in the end."
                  I didn't attend the funeral, but I sent a nice letter saying I approved of it."
                  - Mark Twain
                  • Tom Miller
                    • 2507
                    • Twin Cities, MN
                    I'm getting into this thread a little late, but a starting pin doesn't need to be a pin, per se. It can be the tapered edge of a piece of, say 1x1, that's clamped at the other end to the surface of the router table. The tapered edge serves as the starting "pin". I picked that up from the most excellent Hylton router book.
                    Regards,
                    • Greg.B
                      • 166
                      • Joppa, Maryland
                      Just used this method when routing some walnut that I wanted to come out perfect. Just used some scrap ply right behind it and no tear out for the piece. Best way IMO.
