Best tool to cut hardboard
  • darrellcraig
    • 44
    • Seattle, WA, USA.
    I need to cut two small 8.5"x5.5" pieces of 1/8" hardboard. With what (power or hand tool, just need two pieces) and how would you cut it for the cleanest edge? Or is just a matter of post-cut cleanup with sandpaper? Thx for helping a newbie that hasn't worked with hardboard before.
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    I've always cut it with a TS and gotten good results.
    • Tamarack
      • Oct 2003
      • 199
      • Speedwell, TN USA
      Me too.
      Paul in Idaho (actually in St Louis for a week enroute to Cumberland Gap, TN)
      • havighurst
        • Jun 2004
        • 181
        • Metamora, MI, USA.
        I cut some this weekend with my TS. It came out great.
          • 21992
          yup, T.S. is the best
          • ryan.s
            • 785
            • So Cal
            Another for the the T.S.
            • eezlock
              • 997
              • Charlotte,N.C.
              cutting hardboard
              darrelcraig, like the others have said TS works great, even bandsaw.
              a word of caution before cutting...check to see if the hardboard could slide
              underneath rip fence/miter gauge on either saw, if so you may need to install an auxillary fence that that prevents this from happening....makes for easier
              and safer more controlled cutting possible.I always draw the cutting lines
              for the size I need for finished piece, cut slightly to the waste side of that line and sand to final finished size(drawn lines) on the disc/belt sanding machine.My .02 worth...eezlock
              • darrellcraig
                • 44
                • Seattle, WA, USA.
                thanks much, BT3100 it is followed by some sanding
