I'm sorry that Jeff got frustrated by his HF jig but I still recommend it. I wonder if, after mastering his PC, he could not go back and make the HF work. There are only a couple things unique about the PC that makes it a bit more of the challenge. One is the bar that runs the long direction of the jig for controlling how deep into the front of the drawer you cut. Even the Woodtek instructions are not great for this aspect but once you've cut dovetails successfully, I would think you could see what is going on. I like this feature because I like to use baltic birch plywood that is a bit less than 1/2 inch thick. With my other jig, that causes issues because the minimum thickness it handles is 1/2 inch. I don't know how well the PC handles this. The other thing you may not have to mess with on the PC is the offset of the front to the side. The offset is always 1/2 the dovetail spacing. From looking at the instructions, it appears this is fixed on the PC. This limits flexibility to use alternate template guides but also eliminates one of the things you have to set on the HF. I had used a couple other dovetail jigs when I got my HF so I never had much of a problem. I have a friend that purchased an equivalent jig and got frustrated and gave up on it. My friend is pretty mechanically inclined so maybe I underestimate this drawback of the PC and similar jigs. I need to invite my friend over sometime to see how it is supposed to work. I've made several dozen drawers with my HF and once you understand how it works, it is a very good dovetail jig. Clamping is quick and solid. Jig is all metal with very few exceptions. Should last forever - all for $30.
