Machine Lubing Question
  • IBBugsy
    • 160
    • Allentown, PA.
    Just got the cheap HF Drill Press ( http://www.harborfreight.com/cpi/cta...emnumber=38119 )
    The manual mentions to keep "machined pieces" lightly oiled and nothing else.
    My guess is that
    (1) the base, stand and upright pole have bare metal parts that need a light coat of oil to minimize rust formation. I have some Air Tool oil that's lighter than motor oil that I'll use.
    (2) the moving parts (chuck, spindle) can be hit with WD-40 every now and then to keep them clean and lubricated.
    Sound about right????
    Dave - Weekend Garage Junkie
    "I'm no physicist but I know what matters" - Popeye
    Assuming you're a woodworker, like most of us here, don't use oil on any surface that'll be in contact with wood. It'll hose your finishes. I use the Boeshield T-9 spray on all my big arn tools ... protects against rust, and leaves a silky-smooth coating that feels nice and allows the workpiece to move smoothly over the tables.
    • IBBugsy
      • 160
      • Allentown, PA.
      Yeah, I figured I'd have to wipe off all the oil before I used the drill, then re-apply when done. I'll look into getting some T-9....
      • mpauly
        • 337
        • NJ
        Only part that's going to come into contact with wood would be the table and fence. Wouldn't paste wax work here without the finish contamination issues? Lube the rest of the non contact spots as you like.
        Anyone ever use the dupont teflon lube for coating metal to prevent surface rust? I use it on my bike chains because once it flashes, it's dry and doesn't fling or attract dirt. Might be worth looking into for the non contact parts.
          I've been using the Boeshield T-9 with good results. Seems to work better than wax. Very highly recommended by a Wood magazine (IIRC) review a while back.
