How do you make these air-tight?
    http://www.leevalley.com/wood/page.a...82&cat=1,42401
    http://www.rockler.com/product.cfm?page=1515
    I've seen various versions of these around. With these two particular types, I wonder how you connect the hoses such that they remain air tight. The holes don't seem to have shoulders, just a hole through the thin plastic. I don't know how you'd keep them air-tight.
    Anyone have one of these?
    Thanks,
    Phil
    • 22109
    Thanks,
    Phil
    Most often the hose ends are slightly tapered. The suction in the system will pull the hoses in and keep 'em tight.
      I had one a while back and the lid was tight, and the hoses fit as tight as if they were pushed into the shop vac hole. They didn't leak. Maybe I got lucky.
      • bigsteel15
        • 1079
        • Edmonton, AB
        I have both sizes of the LV units.
        Loring is right about the hose ends being tapered, but what I did on my 4" unit hooked to my DC is turned the hose directly into the lid.
        Either way, even with the smaller unit and shop-vac, there is never an issue about airtight.
        My shop-vac actually sucks the garbage can in when it's turned on.
        Brian
        Welcome to the school of life
        • Lee4847
          • 200
          • Canton, Oh
          I was pondering the same thing. I bought a lid from Rocklers a few weeks ago and have been looking at it thinking their has to be a good way to hold the hose in the top. I was thinking of using silicone to seal/glue the hoses in there.
          And what about the top to the can? I was thinking I would get some foam weather seal.
          Cut twice.... measure??
          • bigsteel15
            • 1079
            • Edmonton, AB
            Not really necessary for the small units on a shop-vac.
            Believe me when I tell you that you won't need to seal it when the shop-vac is on. On the 4" for DC, not a bad idea as the suction isn't as great.
            BTW, I've looked at the Rockler one (ShopFox and Busy Bee have same unit) and personally think the LV is better quality.
            Brian
