Had to edge joint several 12" wide pieces of cedar for LOML's planter box. I had trouble keeping the board upright and against the fence (it was 48" long). Managed to do it OK, but wondering if there is a better technique without losing fingertips? Can a featherboard be attached somehow?
Edge jointing a WIDE board?
Newbie interjection....
Is there a disadvantage to using a table saw instead? Say the two edges are not straight, but the faces had been jointed and planed. If I mount the piece (probably with double stick tape) to a sacrificial plywood with a straight edge that can ride against the fence, I should be able to get a straight edge that's similar to a jointed one, right? Then I can use that first edge against the fence to cut the other edge.
Just wondering, since I'm still trying to sort out techniques.Comment
Anna's idea is good,Originally posted by AnnaIs there a disadvantage to using a table saw instead? Say the two edges are not straight, but the faces had been jointed and planed. If I mount the piece (probably with double stick tape) to a sacrificial plywood with a straight edge that can ride against the fence, I should be able to get a straight edge that's similar to a jointed one, right? Then I can use that first edge against the fence to cut the other edge.
if you must use a jointer then the answer is a tall fence addition like you might use on a table saw. That means finding a way to mount it. If you didn't mind drilling and tapping a couple of holes on the face of your jointer fence ( a seemingly innocuous mod), it would be easy. Juts use a 10" pieceof plywood with a couple of matching holes countersunk a bit to hide the heads of bolts.
Here's how I did it on my jointer. Look half way down this thread for my post and picture on how to make use of cam clamps.Originally posted by MilDocCan a featherboard be attached somehow?
I guess it's not completely clear in the pic, but I just bolted a block of wood to the side of the jointer, and then the featherboard is attached to that.
(I would have just inserted that pic in this thread if I knew how, or if it was possible. I'm not on the computer that has the original pic, or I would upload it again.)
Regards,
TomComment
Paul
I posted this on another question. It applies to your question also.
It's a fact of life that Rule #1 is some rules don't have to be followed. Anyway who makes this stuff up? I did rip cut glue ups on a TS way before I ever got a jointer. I get lucky at times. If your saw is set up right, and you have a straight length and the edge is 90 deg, no reason not to glue up. Your preliminary test of butting both boards together to see a "dry fit" will take some of the mystery out of it. If your jointer is set up right and you are using it correctly, you can get the same results. For long heavy stock it's difficult to manhandle through a jointer.
I've always kept a long straightedge (10') cut from 10' 3/4" plywood. That stuff isn't easy to find, but some distributors carry it. Kept a length about 12" wide and cut it as straight as possible. Then micaed both long edges and used it as a TS straightedge. For lumber that has no long straight edges to start with, I would tack the ply to one side on top of the stock so the ply runs against the fence. And voila, one pass we have a straight edge. No multiple passes through a jointer.
I always felt the largest area that can be set up for side tables and in/outfeed tables makes the TS easier to use. The setups can be fold ups, anything to provide a smooth infeed and outfeed, so that you're not under stress to be balancing wide or long stock through the saw cut. On long stock, I also set up a long infeed panel, not rollers. Concentrating on keeping the stock firmly against the fence will help for a straight cut. All it takes is a slight drift off the fence to screw up that cut and the one that follows.
"I'M NEVER WRONG - BUT I'M NOT ALWAYS RIGHT"Comment
Well, for stuff that is too big for my jointer, I use a MDF shelf from HD as a straight edge, and joint with my router and a pattern maker's bit. For something 48", you could easily do it on the TS as these guys have mentioned.
For me, it gets hairy when I'm in the 6' range, then I just don't want to try and get the thing straight through the TS with the short front end of my BT. So I use a flush trim (or pattern maker's, or you could use a collar and a straight bit). Spiral cutters (as most always) work best.Keith Z. Leonard
Go Steelers!Comment
LCHIEN
