Seeking advice from those who have modified their Harbor Freight 2HP dust collectors for better performance.
The givens:
1. My current shop is a small, temporary arrangement that I'll use only for the next few years until I can build a larger, permanent one. So I don't want to spend a lot of time and money on DC ducting that will have to be transplanted, or possibly even abandoned.
2. Most of the major tools are grouped near the DC. I can reach everything in the shop except my CMS with a single 10' length of 4" hose, without having to roll the unit around.
3. I bought the HF accessory kit with the DC, which means I already own about half the total amount of hose and fittings I need. To get the rest, I was planning to buy a second kit.
4. Every run will have its own blast gate, located as close to the DC unit as I can get it.
5. I am going to do the conversion to a Wynn's cartridge filter and plastic bottom bag.
My questions:
1. All things considered -- small shop, temporary arrangement, no run of hose longer than 10 feet -- can I get acceptable performance in the short run, which is all I'm concerned about for now, by sticking with 4" hose and the 4" extraction ports on my machines? Or do I need to bite the proverbial bullet and open up everything to at least 5"?
2. Am I correct in thinking that this unit is not powerful enough to overcome the additional resistance of a trash can separator?
3. Harbor Freight has a pretty good prices on "compressor duty" motors. Would it be worthwhile to upgrade to a 3HP motor, using the stock impeller? Can this even be done?
4. Other than the stuff listed here ... is there anything else I need to be doing, or not doing?
The givens:
My questions:
LCHIEN
