Need help rewiring motor.
  • ryan.s
    • 785
    • So Cal
    I just picked up a 1 HP Rockwell electric motor today at a yard sale for a couple of bucks. The motor runs fine but I want to update the cord on it since it's showing some wear. The original cord is an older 2 prong plug. I'm thinking of getting one of those tool replacement cords from HD rated for 15amps with a 3 prong plug. Where would I attach the ground wire on the motor? Should I just not connect the ground wire on the new cord?
    Thanks!
  • sbs
    • Mar 2005
    • 126
    • VA
    • BT3.1k
    Thanks!
    Attach the ground to the case using either an existing screw or a sheet metal screw.
    • Rslaugh
      • 609
      • Punta Gorda, FL, USA.
      • None right now
      I wouldn't drill a new hole for a sheet metal screw unless you know exactly what's on the other side of the intended hole.
      Rick
      IG: @rslaugh_photography
      A sailor travels to many lands, Any place he pleases
      And he always remembers to wash his hands, So's he don't gets no diseases
      ~PeeWee Herman~
        exactly!
        or, in a pinch anywhere on the metal frame of the tool if the motor is firmly bolted to it.
        • ryan.s
          • 785
          • So Cal
          Thanks guys!
