tuning a new drill press
  • milanuk
    • 287
    • Wenatchee, WA, USA.
    The thread about all the neat things you can do w/ a drill press brought to mind a question when someone mentioned being able to drill perfectly perpendicular holes.
    Question is, how do you (as in you, personally) go about making *sure* that your drill press is perfectly set up for 90°?
    Just go by the angle indicator on the table? Use a square and a long drill bit? One method I saw in a magazine somewhere this summer involved drilling holes in a block of MDF, and then sticking a precision-ground rod in the resulting hole and measuring whether it was then perpendicular w/ the surface. Seemed a little overboard to me at the time, but now that I have a brand-spankin-new DP400, I'm wondering...
    TIA,
    Monte
    All right, breaks over. Back on your heads!
    I square mine against the table.
    I use a stiff, straight metal rod or a good bit (like 1/4 to 1/2") chucked up and made sure to have minimal runout.
    Then check the squareness to the table in both the right left plane and check the front-back plane (not sure what to do about it if its not...!).
    Set the table square to the blade by adjusting the table tilt and then verify it says zero and adjust the indicator (if possible).
    I also try to get the table flat dead level to a bubble level by shimming the whole drill press. This ensures the bit is aboslutely perpendicular to, and the table is parallel to, the plane of the earth's surface.
    By having the bubble level flat dead I can drill square into the end of long pieces of wood and dowel by using the vertical bubbles of a level to check the item usually clamped at the very bottom is perfectly upright.
    I haven't checked these for a long time... but do so every once in a while. I don't expect them to go out and haven't had any fit/drill problems indicating this might have happened.
    • Stick
      • 872
      • Grand Rapids, MB, Canada.
      TIA,
      Monte
      What Loring said. I use drill rod and machinist's square to check the table, and a machinist's level to check the whole machine's level. I bolt mine down to the floor, so that never moves. The 90° stops are often inaccurate on consumer type drill presses. Don't trust them until you check them.
      • Stytooner
        Roll Tide RIP Lee
        • 4301
        • Robertsdale, AL, USA.
        If the table on a DP is a little wonky from front to back, you can loosen up the bolt that adjusts the left and right tilt. Slip aa shim or an old feeler guage in at the top of the crack or bottom as needed and tighten back up.
          Simplicity:
          Mark "Woodmangler" had the most simple setup that I have ever seen. He chucked a 12 to 15 inch piece of coat hanger wire. It came out of the chuck, was bent to a semi- right angle by hand for about 4 or 5 inches and then bent down to the table. It does not have to be pretty. Rotate the spindle by hand and see where it touches and where it does not touch and adjust from there. When it barely touches all the way around, the table is square with the chuck, period! [8D]
          • jstevens
            • 125
            • Ardmore, PA, USA.
            That's exactly the problem my drill press has. For anyone planning on making a table to fit over the original one, it's pretty easy to compensate for the tilt when designing and making the table. Plenty of ways to skin that cat--shims, adjusting screws, gradually trim shavings off the base with a plane until level, etc.
            Otherwise, I'm not sure what you would do. My Ridgid DP has no provision for adjustment in that direction. Perhaps more expensive DPs do?
            Regards,
            John
            • vinht
              • 391
              • North Andover, MA, USA.
              Regards,
              John
              I'm new to drill presses since I just got mine yesterday. The first thing I did was search online for tuning instructions. Unfortunately, all I found were books on the subject.
              Regarding the table being level, as long as the bit is perpendicular to the table does it matter if it's level in relation to the floor or in my case the bench top? Kind of like the torsion box theory?
              Vinh
              A Woodworker\'s Journey
              http://vinht.home.comcast.net
                Regards,
                John
                Vinh
                If the table is not perpendicular to the bit front to back, then the DP is defective IMHO.
                As for the table being level, I explained that.
                Its not neceeesary to drilling but when setting up tall pieces to be drilled, you can make the piece vertical with a bubble level and be assured you are going straight in the end. Otherwise, its difficult.
                • vinht
                  • 391
                  Thanks for the clarification Loring, I think I understand.
                  By the way, Monte, I found this online. Not sure how well it would work though....
                  http://www.woodworkingtips.com/woodtips/wbtip05.html
                  I'm thinking of getting this book. Anyone have this?
                  http://www.amazon.com/exec/obidos/AS...696142-7318338
                  Vinh
                    Although not strictly necessary for a drill press (except for situations such as Loring described), I'm a big believer in having everything in the shop as close to perfectly level and plumb as possible. If things are sitting cattywampus, your eye will be fooled and you'll have a harder time judging when your projects are assembled nice and square, like they're supposed to be, and when they're out of whack. A critical eye is one of your most important tools; you don't want to give it any unnecessary obstacles to overcome.
                    • Tom Miller
                      • 2507
                      • Twin Cities, MN
                      For those of you with a dial indicator:
                      I suggest rotating the chuck by hand. [B)]
                      Regards,
                      • milanuk
                        • 287
                        Vinh
                        Ya know, I do. And I completely friggin' forgot about there being drill press stuff in it
                        I'll take a look at it in the morning when I get off work and see what it has to say and let you know. I remember looking a lot at the stuff on the jointer and for a 'regular' i.e. non BT3K table saw and it was pretty detailed and informative for people like me who have no one else more experienced at hand for a mentor.
                        Monte
                        • gjsgjsgjs
                          • 26
                          even cheaper at overstock.com
                          http://www.overstock.com/cgi-bin/d2....PROD_ID=158396
