BABY Drum Sander
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    BABY Drum Sander
    Even though they said it was BO until mid July, my new Grizzly "Baby" Drum Sander arrived today.
    If this is a "baby" then I hate to see what a full grown one will look like. It doesn't weigh 200 lbs, as predicted, only 150 lbs. But, it looks huge. I had envisioned it to be the size of my 12" Delta planer. It is wider and about three times as deep.
    I'll have to move things around a bit in my already overcrowded shop, before I can take it for a spin.
    Does anyone else have one yet? I'd appreciate any hints or opinions.
    Steve
  • gary
    • 893
    • Versailles, KY, USA.
    Not a proper gloat until you post a link to the Grizzly site or a picture. Until then, you only get a lower case "you suck".
    Gary
    • Holbren
      • Oct 2004
      • 709
      • Orange City, FL.
      Post a pic and let us know how you like it. I'm going to buy one eventually but was looking at the Performax 10/20 for bench top use. I don't have any more floor space in my little shop area.
      What is the min sanding thickness? I will be using my probably mostly for sanding resawn veneers and some of them have a min thickness that is not good for that.
      Brian
      www.holbren.com
      • Jeffrey Schronce
        • 3822
        • York, PA, USA.
        • 22124
        I bet there will be good deals to be found on the Performax line since they are rebranding the line to Jet. A few places already have the Jet instead of the Performax.
        • Holbren
          • Oct 2004
          • 709
          • Orange City, FL.
          Funny you say that Jeff. I went to Amazon and checked prices on the Performax and the "new" prices are higher than the ones crossed out. Maybe there is a given % off sale going and they jacked them up for the sale.
          I don't understand why those machines are so expensive other than the fact there is little competition. Maybe there is some precision in the bearings and shaft or something that cost some $$$ to produce.
          Brian
          www.holbren.com
            I'm probably going to get a performax sander, but I agree that there isn't enough competition out there for these tools. The Griz's 12" capacity is somewhat limiting for flatening large glue-ups, but probably just the ticket for home made veneers, as most people can't resaw more than 12" at home.
            The delta is the only competitive tool. The performax sanders do work well, and I've used them.
            • Jeffrey Schronce
              • 3822
              • York, PA, USA.
              • 22124
              Seems the Delta may be able to create some competition with their machines. How long have they been around? I only recently became aware of them.
              • Tundra_Man
                • 1589
                • Sioux Falls, SD, USA.
                I looked at the Grizzly last January when I bought my sander. I wound up going with the Performax 10/20, mainly due to the weight/size issue. With my small shop I didn't have anywhere to put a larger machine. The Performax is 100 lbs and is a bear to move around, so I can't imagine hefting the Grizzly into place.
                As far as hints, dust collection is not an option. Your sanding belt will clog in a heartbeat without it. And a shop-vac probably doesn't have enough "oomph" to keep up with a sander. Make sure you adjust it so the drum is parallel to the table. That's a critical adjustment, as having it slightly off can ruin your day. Also, buy one of those rubber sanding belt cleaning sticks. Your sandpaper will last a lot longer if you use those regularly.
                Let us know how the Grizzly works once you put it through it's paces.
                Terry
                • bmyers
                  • Jun 2003
                  • 1371
                  • Fishkill, NY
                  • bt 3100
                  here is a REAL baby drum sander I found on the net..
                    I have to agree, Steve, there just isn't really enough room in you shop. I'd be happy to find a home for this for a while.
                    • bmyers
                      • Jun 2003
                      • 1371
                      • Fishkill, NY
                      • bt 3100
                      actually you could prolly use that baby drum sander for skeet shooting also if you run the boards the wrong way.
                      • scmhogg
                        • 1839
                        OK Gary here's the link. No pics yet as it is still in the box.
                        http://www.grizzly.com/products/G0459
                        JR that's mighty neighborly of you. I'll keep the sander, but you could store 6 or 7 file cabinets with old files in them.
                        Steve
                        • aksarben1010
                          • 6
                          The size and weight are pretty big for something that is called 'BABY'.
                          I was going to buy one when they came out but I got really lucky and found a used Performax 16/32 for $300 with the legs, caster and in/outfeed tables plus tons of sandpaper. I could not resist a deal like that.
                          I can tell you that it has changed the way I work, I use it alot. I got it to go with my bandsaw to get rid of resawing marks. I have since found a lot more uses for it.
                          Enjoy it and built a cart for that thing so you can move it. At 150lbs you will throw your back out lifting it.
                          Scott
                            Hmm...
                            Any of them labeled "Anthony Pelicano"?
                            • Holbren
                              • Oct 2004
                              • 709
                              • Orange City, FL.
                              Man, I never find those deals. That is a deal and a half.
                              Brian
                              www.holbren.com
