DC system setup
  • venkatbo
    • 243
    • Cupertino, CA, USA.
    DC system setup
    Hi folks,
    I got myself a Delta 50-760 1.5HP Dust Collector for the garage wwshop.
    'am totally clueless as to the design and setup of the piping, Y-splitters, etc., to hook this DC system.
    Could someone point me to resources on the design such a system. I don't think assembling the Delta 50-760 would be an issue... just all the other stuff that needs to be installed before hooking up the Delta 50-760.
    Thanks,
    /venkat
  • bigsteel15
    • 1079
    • Edmonton, AB
    http://billpentz.com/woodworking/cyc...tionBasics.cfm
    this is where you will get the best info.
    Brian
    Welcome to the school of life
    • Tom Miller
      • 2507
      • Twin Cities, MN
      venkat,
      Have you decided what kind of piping you want to use? I'd suggest 4" S&D PVC, due to it's appropriate size, low cost (for pipe AND fittings), and because it works well with other DC fittings.
      You can make a "main line" from the DC to the farthest tool, and then install "drops" to each tool from there. The picture shows a wye connection, which is a good way to branch off a main line. Use another 45 degree elbow to make a full 90 degree bend.
      This picture will give you a basic idea of how to connect 4" DC hose (Rockler, Woodcraft) to the 4" S&D. The metal blastgates are a good fit into 4" S&D, and the S&D, in turn, is a good fit over many 4" dust ports on tools. Put blast gates on each drop as close to the main line as you can.
      Try to minimize the # of elbows, and use large-radius 90's when you can.
Name:	DC Connections2.jpg
      Uhhh, disregard the 3" PVC plumbing behind the 4" S&D.
      Regards,
      • venkatbo
        • 243
        Thanks Brian & Tom.
        Tom, pardon my ignorance - but what does S&D stand for :?)
        Thanks,
        /venkat
          • 22109
          Originally posted by venkatbo
          Thanks Brian & Tom.
          Thanks,
          /venkat
          Sewer and drain (e.g. low pressure usage)
          • bigsteel15
            • 1079
            • Edmonton, AB
            Hey guys, I'm at the same stage regarding DC system.
            I took a 4" adapter (one end the hose fits on and the other end fits over the tool outley) with me to HD and I can't see how you get 4" S&D pipe to work
            the big end of the adapter is the same OD as pipe.
            Now I didn't take flex with me. will it fit over the pipe?
            Tom, what is the green piece you ahve the hose attached to?
            Brian
            • vinht
              • 391
              • North Andover, MA, USA.
              Venkat,
              Where did you get your new DC? I've been holding out for a decent sale for the 50-760 but nothing so far. Did you get a deal?
              Thanks,
              Vinh
              A Woodworker\'s Journey
              http://vinht.home.comcast.net
              • venkatbo
                • 243
                Vinh,
                I got this a while back for ~$175 or so cant recall properly... Just getting
                to hook it up.
                If you have the patience, you can get the HF model and add the 1micron
                bag - search the forum for the 1micron-bag supplier. It's come to ~$155
                or so. <=1micron is highly recommended for healthy lungs :-)
                /venkat
                • Tom Miller
                  • 2507
                  • Twin Cities, MN
                  That green piece is just a short section of S&D. If you have a fitting that is the same OD as S&D, then you could use a PVC coupler (used to join 2 pieces of S&D). OR, since a 10' piece of S&D comes with a ~6" section on the end that's oversized to slip over the next piece, you can use that portion to couple.
                  The flex hose that I get at Rockler will just fit snugly over S&D; usually I remove a few winds of reinforcing wire, and add a hose clamp like in the picture.
                  (Note that the fittings for S&D are different than for Schedule 40 pvc.)
                  Regards,
                  • Brian G
                    • Jun 2003
                    • 993
                    • Bloomington, Minnesota.
                    • G0899
                    Tom, as I recall, you use Schedule 35 S&D, correct?
                    Brian
                      venkat,
                      Regards,
                      So disregarding the 3" plumbing, any reason you used pvc before the s&d pipe? Any reason not to do the same (possible access).
                      Thanks
                      • bigsteel15
                        • 1079
                        • Edmonton, AB
                        Regards,
                        Thanks Tom.
                        I realized that I answered my own question after I wrote that.
                        this is what I was talking about and it looks like it will likely fit the belled end of the fittings for the PVC and the flex screws right onto it.
                        http://busybeetools.ca/cgi-bin/pictu...5&NTITEM=W1036
                        Brian
                        • MilDoc
                          Woodshop Dust Control : A Complete Guide to Setting Up Your Own System: Completely Revised and Updated (Paperback)
                          Best reference I ever found.
                          • Tom Miller
                            • 2507
                            • Twin Cities, MN
                            Thanks
                            I'm not quite following -- which PVC are you refering to? The wye? Any reason not to do the same as what? (Sorry, major case of brain-dead this AM.)
                            Brian (Knuckles): Yep schedule 35, aka SDR35, or ASTM 3034, which is ~1/8" wall thickness for 4" diam. There's also thinner-wall stuff out there, ASTM 2729, at a bit over 1/16" wall. That stuff is probably too thin. (SDR stands for "standard dimension ratio", the ratio of wall thickness to diameter, with some multiplication factor. A given SDR will have the same pressure rating, no matter the pipe size, as bigger pipe will have commensurately thicker walls.)
                            Brian (bigsteel15): Right, if a DC part doesn't fit inside the S&D pipe, it'll probably fit inside a S&D fitting. And then getting it connected to the pipe is a done deal.
                            Regards,
                            • Brian G
                              • Jun 2003
                              • 993
                              • G0899
                              This time I wrote it down. I knew you posted it before, but each time I tried to search for it, I couldn't find it.
                              I was in the Eden Prairie HD tonight. They have the SDR35 in an attractive gray color.
                              Brian
