Delta 10" BS
  • bigsteel15
    • 1079
    • Edmonton, AB
    Delta 10" BS
    So last fall I bought a 10" Delta BS as part of a package deal I made at a WW show here (BS, 6" jointer, 13" planer w/mobile cart, 1 HP DC)
    Anyways, yesterday I decided that I wanted to resaw some mahogany for a project I have planned and I started thinking that I might have to upgrade before I've even used my BS believing that I could probably resaw maximum 3-1/2" on my BS.
    I went and measured and holy cow...7" capacity.
    My BS is a Delta BS150LS
    http://www.deltamachinery.com/index.asp?e=136&p=5840
    Am I actually going to be able to successfully resaw 7" thick material on this saw, assuming I can actually find a 1/2" blade.
    The blade length is 72-1/2", seems to be an oddball length.
    Brian
    Welcome to the school of life
  • Stormbringer
    • 1387
    • Floral Park, NY
    • Bosch 4000
    Brian ,
    I don't have the saw but these may be of help
    http://laminateflooring.oncloud8.com..._0__index.html
    And ths one from Amazon....reviews vary but this one addresses your question
    not enough saw for the format, July 19, 2005
    Reviewer:B. watford "fretless creations" (Birmingham,AL) - See all my reviews
    This is a decent bandsaw for 10" applications,but,it boasts a 7" resaw depth where most 10" bandsaws have a 3" to 4" resaw depth. The resaw depth is the entire reason I bought this saw, but it is not strong or powerful enough to resaw 7" thick hardwood. It boggs down and actually comes to a grinding stop constantly when trying to cut anything medium hard over 4". The deep resaw depth was a great idea, but it just doesn't work very well. Also the saw arrived with a broken foot, top tire far out of balance, and within a week. the bottom thrust bearing froze.
    Was this review helpful to you? (Report this) (Report this)
    Good luck,
    Greg
      well 7" resaw is nice. and the spec on the delta page says it can take 1/8th to 1/2" blade width.
      I guess the power is the question. You already own it, buy a timberwolf resaw blade (3 tpi skiptooth or whatever they recommend) from www.sulfolkmachinery.com, for around $20? and
      try it.
        Mahogany is pretty soft, so you might just be able to pull it off.
        • Jeffrey Schronce
          • 3822
          • York, PA, USA.
          • 22124
          try it.
          Absolutely. A great blade such as the Timberwolf (I think they will recommend the 3 tpi) will make a huge difference. Most likely the Amazon reviewer was using the stock blade, which tends to be crap. Also, Timberwolf will have any size you need.
          • bigsteel15
            • 1079
            • Edmonton, AB
            Update
            Ordered a 1/2" 3 TPI blade from the local supplier that gets them made here in town.
            I'll have to do some fine tuning of the tracking before I trust the mahogany to it.
            I gave the stock 1/4" blade a shot at re-sawing a 2x4 and it didn't do too bad for hand held, no fence.
            1/32"-1/16" thickness difference top to bottom could have been me.
            Brian
