I don't own an RAS but my dad always had one, in lieu of a table saw; it's what I learned on and was all I used for many years.
In the context of the above, you're right: with those three saws already in your arsenal, there's really nothing a RAS will do that you can't already do, one way or another. If you have a given tool in your shop, you'll find a use for it -- typically those jobs it does a little quicker or easier than some other tool can. But as Keith says, there are always other ways.
Radial arms pre-date compound miter saws, and in the hands of contractors those big old honking DeWalts were probably used more for trim cut-off work than anything else. When the CMS came along, it more or less killed off the RAS because it would do everything the average RAS was being used for, in a smaller, lighter, less fussy package.
In amateur shops, Sears sold a ton of Craftsman RASes in part because they touted all manner of attachments that would turn an RAS into something akin to a ShopSmith: molding cutterheads, routing attachments, drum sander attachments, etc etc etc. Most of these things worked better in the catalog than they did in the shop.
The result of the above is that the RAS is to a large extent skating on its past reputation. It will do dados well, at least up to its cross-cut capacity (more on this in a minute), but you'd have to cut an awful lot of dados to make one worth having JUST for this job. BTW and FWIW, dadoing is about all I can remember Norm Abram ever using his for on NYW; and while David Marks has an RAS sitting in his shop, I can't recall him ever using it on any episode of WoodWorks.
Wider crosscut capacity (compared to a CMS or SCMS) is one oft-mentioned advantage of the RAS, and that's true. But I've never quite bought into this argument because while extra capacity is always good, the 16" or so that a RAS will cut isn't wide enough for base cabinets or furniture like hutches and dressers and chests-of-drawers, which usually run between 20"-24". So yes, an RAS will cut wider material than a CMS, but it's still not wide enough for everything ... so sooner or later, you're back at the table saw. If you building, say, a china cabinet with a shallow upper section and a deeper lower section, and dados for both, you'd probably put the dado set on the TS and cut everything with it. OTOH if I owned a cabinet shop that built a lot of bookshelves and/or wall cabinets, especially with dados for joinery, I'd want an RAS on the shop floor.
I too own a TS, CMS, and BS, and don't miss not having an RAS at all. Which is not say I wouldn't snap one up for $100-150 if one came along at that price. But it would be more a case of opportunity than of real need. If you want one, you want one; if you have the money and space, go for it. But given the tooling you already have, there are probably other things that should have a higher priority.
