snipe effect in planer
  • xli1
    • May 2006
    • 151
    • Big Boston Area
    • Ryobi BT3100-1
    I have a delta TP305 thickness planer. But it is kind of annoying that I always get about 2" snipe on both ends of the stock. This wastes a lot of material since I have to cut it out, especially when I plane wide board that is pre-cut to the size. I have tried to feed a short (about 8 - 10") stock with the same thickness before the stock I am going to plane and one after immediately after. This seems to work in many cases, but sometime I still can not avoid it. I don't know anyone here knows how to avoid this kind of effect? Are there any other brands with similar price range do not have snipe effect?
    http://woodworkingdiy.googlepages.com
    IIRC that unit does not have a cutterhead lock. A cutterhead lock and a four-post construction does a lot to reduce it greatly but does not 100% eliminate it. Those features are found in the more expensive units.
    • Ken Weaver
      • 2417
      • Clemson, SC, USA
      • Rigid TS3650
      Check your infeed and out feed tables - they may not be set right. Check your manual. Otherwise, give the rollers a good cleaning. I have the Ridgid and the only time I get any snipe is when I don't clean the rollers regularly.
      Ken Weaver
      Clemson, SC
        Try adjusting the infeed/outfeed with the nickel method. Adjust the tables so a sraight edge resting on the ends of the tables is the height of a nickel in the center.
        • bmyers
          • Jun 2003
          • 1371
          • Fishkill, NY
          • bt 3100
          all that and get a piece of melamine 3-4 feet long and use it as the bed. Make a stop on the infeed side to rest against the infeed table edge (so as not to get sucked through also...)
          • Deadhead
            • 490
            • Maidens, Virginia, USA.
            Are you saying make the tables higher than the center? Could you elaborate some more on this? I have snipe with my AP1300.
            "Success is gettin' what you want; Happiness is wantin' what you get." - Brother Dave Gardner (1926-1983)
            • Ken Weaver
              • 2417
              • Clemson, SC, USA
              • Rigid TS3650
              Yes - slightly, the thickness of a nickel is a rule of thumb. Other wise there's no pressure to keep the board against the blades and rollers.
              Ken Weaver
              Clemson, SC
              • xli1
                • May 2006
                • 151
                • Big Boston Area
                • Ryobi BT3100-1
                Thanks for the input. I have done some research on internet. Here are several articles talking about this:
                http://www.woodezine.com/08_2004/0804_snipe.html
                http://www.newwoodworker.com/plnrsuprt.html
                http://www.tools-for-woodworking.com...n=Custom&ID=67
                The snipe effect is limitation of the planer design. A cutterhead lock and a four-post construction do help but can not completely solve the problem. People have come out several ways to minimize the snipe, but seems none of them can eliminate it. What I am thinking is that the combination of all these tricks will reduce the snipe effect to a minimum. Here is what you can do:
                1. adjust the infeed and outfeed table to be slight higher than the center (nickel method);
                2. extend the infeed and outfeed table for better support, so you can have at least several feet on both sides;
                3. feed scrap piece of wood (about 8-10" long) with the same thickness immediately before and after your stock. People are glue the scrap piece to the both ends of the stock, which I think is not necessary, it also increase the amout of effort.
                Hopefully this will help solve the problem.
