Shear angle flush trim bit
  • newood2
    • 600
    • Brooklyn, NY.
    I see MLCS have these new bits. Do they cut smoother than the regular flush trim 2-flute and 3-flute bits?
    I want to go ahead and try one of them, but just checking if you guys ever use them or have an opinion on them.
    http://www.mlcswoodworking.com/shops...r_angle_anchor
    Howie
    I have one, it cuts cleaner than regular flush trim bit, but falls far short of a spiral cutter. The spiral flush trim is certainly the best.
    • MilDoc
      Uh, is this just a regular spiral bit used for flush trimming, or a special one with a bearing for pattern following? If the latter, got a link?
        It's a spiral flush trim. A spiral bit with a bearing for pattern work.
        http://www.mlcswoodworking.com/shops...ushtrim_anchor
        http://www.woodcraft.com/family.aspx?familyid=8004
          Wow, the woodcraft 1/8" carbide spiral with brass bearing - I'll bet you look crosswise at that, it'll break, especially if you put any side pressure on the that bearing/ lever arm.
            I spent the $$$ for a pair of Whiteside's. 1/2" and 1/4". well worth it!
