Bosch 1617 kit
    Bosch 1617 kit
    I picked one up today at Rockler with a 10% off coupon. Came to 190$, which seems pretty good to me. Anyway, here are some thoughts.
    1. No spindle lock, I wish it had one, but the 2 wrench system isn't bad either.
    2. Base changing, smooth and incredibly easy.
    3. Plunge base, seriously smooth, I have to watch myself that I'm not pushing down to hard on it when I use the rocker to unlock the height. It takes so little effort, very controlable.
    I'm pretty happy with the purchase, I've read that there may be a power switch issue with it, and I hope that Bosch works that one out.
    Now to just get a lift with a quick release for this puppy...
    If you got the new fixed base, you can mount it in a table, drill one hole and set the height from above the table using a long T-handle allen/hex wrench.
      Yeah, I saw that accessory. I've used the jess'em fx lift, and you can literally get 1/512" accuracy with it. I wonder how accurate you can be with that bosch above the table setup. Anyway have any experience with it??
      • ryan.s
        • 785
        • So Cal
        Do you know if they have similar bases for the PC routers as well or is it just for the Bosch.
        • monte
          ***** Windbag
          • 5242
          • Paw Paw, MI, USA.
          • GI 50-185M
          I mounted my fixed base in the table just for this reason. It works very smoothly and makes bit height adjustments very easy. The T-handle allen wrench was included with the router kit.
          Monte (another darksider)
            ryan, there is a PC above the table height adjustment. The only trouble with it could be that the PC height adjuster has more play in it than the Bosch does. I noticed while playing around with them both trying to decide which one to get, the Bosch seems much "tighter" if you know what I mean.
            • dpb
              • 15
              • Baytown, TX, USA.
              You might want to look at buying the Template Guides from Amazon as they are the cheapest I found because Bosch uses a different system than the regular PC style.
              Bosch Part # RA1125-7 - $22.95 at Amazon
              Set includes a bushing that will allow PC Style Guides.
              Thanks
              Derek
