Cleaning the BT
  • kmk
    • 415
    • .Portland, Oregon
    Cleaning the BT
    I was using my air compressor (porter cable 6 gallon one that came with 2 nailers) this morning to clean the BT.( I only cut couple of plywoods and MDFs yet there was so much fine dust. geez!). I was not happy with the blow gun's output so I was looking into the air compressor accessory kit I bought at HD ($14 has small nozzles for various use). I found a little black cone sized thing with small gun hole) and attached it to the blow gun and tried yet. Whoa! that was awesome power! Now, I didnt have to remove the panel and just few shots and all the dust were gone..
  • lcm1947
    • 1490
    • Austin, Texas
    • BT 3100-1
    Yeah ain't compressed air neat! Sounds like you got the same type air nozzle that I have and it does put out some air for cleaning stuff. I still like taking the sides off though as I only clean every 6 months or so and it's such a hassle to put that one side with the plug back together. One of these days I figure out a way to make it simpler but until then I'm not taking that side off any more then I have to.
    • WEG
      • 298
      • Nahant, MA.
      Hi Mac;
      Yeh, I know what you mean about lining up that panel with the electric stuff. I moved the ground position from the side panel to the front panel, and it helped a lot, but putting that panel back never seems to go right the first time..or the second...
      WEG
      • lcm1947
        • 1490
        • Austin, Texas
        • BT 3100-1
        Hey WEG. Yeah I too moved the ground wire but it needs more then that I'm afraid to make it easy. I've seen where one member replaced the whole side with a wooden panel but I'm not that brave or creative.
        • WayneJ
          • 785
          For a quicky clean up, i'll move mine out of the shop and lean it on its side . Then fire up my leaf blower and have at it. The saw dust then becomes lawn fertilizer.
          Wayne
          Wayne J
          • Ken Weaver
            • 2417
            • Clemson, SC, USA
            • Rigid TS3650
            The ground wire is a PITA - I moved mine and it made it much easier than it was. I generally take things apart every 6 months (or after a really major project) and clean it all out and relube the lift mechanism. Keeps things smooth.
            Ken Weaver
            Clemson, SC
            • lcm1947
              • 1490
              • Austin, Texas
              • BT 3100-1
              What is a PITA?
              • ted van halen
                • 76
                Originally posted by lcm1947
                What is a PITA?
                Pain
                In
                The
                A$$
                Or a flat bread good for making sandwiches & wraps.
                Ken, Which did you mean?
                Ted
                  • 22109
                  Mac, that would be in the FAQ/Acronyms.
                  • Ken Weaver
                    • 2417
                    • Clemson, SC, USA
                    • Rigid TS3650
                    Originally posted by ted van halen
                    Pain
                    In
                    The
                    A$$
                    Ted
                    The former
                    Ken Weaver
                    Clemson, SC
                    • lcm1947
                      • 1490
                      • Austin, Texas
                      • BT 3100-1
                      Oh, OK thanks. I thought it was a bread. And Loring I forgot about that.
