When To Sharpen
  • onedash
    • Mar 2005
    • 1013
    • Craftsman 22124
    When To Sharpen
    Is there a rule of thumb for when to get your blade sharpened?
    Since the performance decreases gradually over time its hard to notice that its not at its peak anymore. What im wondering is how long do you wait? Is there any fancy trick or test to know its time to get it sharpened?
    I have several blades and I guess the reason the new one always seems better is because the other one wasn't new any more. So im sure a new clean blade is better than the best blade that is old and dull? Not that mine are old an wore out but I know they are not as sharp as they were new.
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    If you're fussy about your blades and you're in doubt...sharpen it. At the very least give a good cleaning and see if you notice a difference....if not, it would probably benefit from a sharpening.
    I'm just a weekend hack and tend to go 1-2 years between sharpenings depending on what I've been cutting, and how everything seems to be working. I'm pretty religious about cleaning them regularly though.
    • Boomer_01
      • 79
      What to look for
      Here are some things to look for with a dull blade:
      Burn marks on the cut edge of the stock.
      Ragged exit cuts on the down face or end exits.
      A marked increase in blade noise (Whine).
      Excessive force needed to feed stock through the blade.
      A burnt wood aroma permeating your shop every time you use the saw.
      The motor bogging down on normal rip or cross cuts.
      I usually watch my blade performance pretty close. My sharpening service only charges $7 to resharpen my 10" blades so I have them done after every large project.
      Boomer
      • maxparot
        • 1421
        • Mesa, Arizona, USA.
        • BT3100 w/ wide table kit
        First thing to try before sharpening a blade is simply to clean it! If this restores it to satisfactory condition then go no further.
        Opinions are like gas;
          Boomer
          Around here they charge $.30 per tooth for carbide blades.
          Who does your sharpening?
          • onedash
            • Mar 2005
            • 1013
            • Craftsman 22124
            Boomer
            Guess im due for some sharpening then....I thought maybe oak was harder to cut than lyptus but I think it might just be time to sharpen the blades.
              My method of deciding is to clean with CMT cleaner. It works pretty well but by the time I clean there is enough gunk I have to wipe each tooth. While I am wiping the teeth I look at each tooth. When there are pieces missing or the edges of the teeth are not sharp, it is time to sharpen the blade. If the edges still are sharp and there are no pieces missing, I keep using the blade.
              There is some increase in feed required while the edges of the blade still look pretty good but with a clean blade and a well adjusted saw, there should be either no burning with a wood like oak that is not prone to burning or only a little light burning with something like maple that burns easily (and then only if your feed rate is not real smooth). I agree with Loring's comments, I just think it's easier and less subjective to look at the teeth.
