HF Forstner bit set opinions?
    Are the titanium nitride Forstner bits carried at Harbor Freight any good? Does the titanium nitride buy me anything really? I work with quite a bit of plywood, particle board, and MDF.
    Thanks,
    Phil
  • dkhoward
    • 873
    • Lubbock, Texas, USA.
    • bt3000
    I don't know about the titanium (no metalurgical background), but I have a set of the HF bits and they work great for me. Of course, I am a part time hobby type user.
    Dennis K Howard
      I have the HF Tn ones and they are OK. I would buy them again as opposed to two to three times the price for other brands at another store. I don't use them often but when I do, they do an OK job.
        I have a set of the HF TiN forstner bits (1/16ths to 2") and I believe I am pretty happy with them. I have not used any truly expensive ones so I have no comparison, however they seem to be pretty well finished and run true. I cut 92 holes to day with the 1-1/4" bit.
        The TiN coating is supposed to help resist heat buildup that detempers the steel - It's both harder and slipperier than the base metal. the bit lasts longer and cuts better.
          Quite good for the money.
          I have both of the 7-piece HaFr Forstner bit sets (plain, TiN). IIRC I caught the latter on sale for some absurdly low price, like $3.99. Either set is well worth that. I can't detect a whole lot of difference made by the TiN coating but I'd say they maybe cut a little bit better. Maybe.
          However, I should also mention that I own one (only) Freud "Precision Shear" Forstner bit and the difference between it and the HaFr cheapies is truly night and day.
          • uglystick
            • 119
            • Garland, TX, USA
            • Ridgid R4511 Granite top
            HF 7pc TiN Forstner set
            I also have the 7pc TiN set from HF. No complaints for the few sizes I've used so far in plywood and some cherry. A great value in my opinion. Remember to adjust the speed of your drill press!
            -Kendall
            • zootroy
              • Oct 2005
              • 321
              • Coeur D\'Alene, Idaho.
              7pc TiN
              another vote. No problems to date. Used the 1/2" for about 20 mortises.
