3-flute versus 2-flute trim bit
  • newood2
    • 600
    • Brooklyn, NY.
    Is one better than the other?
    I'm looking to buy 1.5" cutting length trim bit from MLCS and they're pushing the 3-flute as a better bit.
  • DaveW
    • 415
    • So Cal.
    In theory, three cutting surfaces would spread the wear and tear and the bit would last longer (I think that's Dewalt's claim with their three-blade planer too).
    Whether it's true or not, I don't know though.
    • Russianwolf
      • 3152
      • Martinsburg, WV, USA.
      • One of them there Toy saws
      Not only does it cut down wear and tear, but it multiplies the number of cuts your getting. This results in each cut being smaller and finer which should equal a smoother surface.
      Lakota's Dad
        They're both right.
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          Not sure about three, but I know four is more desireable for an edge cut and two on a dado when talking about end mills. Not sure how that works, but its possibly due to the heat and vibration effects on the tool when buried. I use that priciple in woodworking too and it serves me well. Two flute for dados. More flutes if possible for edge cutting.
            If this is for flush trim, then the best is the spiral, but I'd pick the 3 flute over the 2 for the reasons already stated. Higher cuts per minute mean smaller cuts being made, which should result in less tearout issues.
