I have PSI Long Ranger I am going to install this weekend. My DC will be connected to it. This is the model that is activated by opening the gates.
Ok, so there are two posts (relay terminals) on top of the unit and I connect a black wire and red wire. Along the length I splice wire to run to gates. However at the end should I simply connect the end to the last gate ? Or should I splice last gate in and have wire left over on the end? Would I need to wire the two ends together to make the relay loop?
I hope this makes sense though I doubt it does!
