What am I doing wrong - breaking bits....
  • vaking
    • 1428
    • Montclair, NJ, USA.
    • Ryobi BT3100-1
    Eric,
    When I need something that small I prefer dremel bits with 1/8" shank.
    In this case - check dremel model 9901 bit - spiral solid carbide multi-flute bit (I mean multi-flute, not 2 or 3 flutes). HD has it, Sears has a similar bit with Craftsman name. In most bits the weakest point is transition, so for a 1/8" cutting diameter bit 1/8" shank is actually the best as long as the bit is not too long. You will need to have 1/8" collet, either there are reducers from 1/4" to 1/8" or there are small routers that come with 1/8" collet originally. I have a rotozip which I use as my trim router and it comes with 1/8" collet. Rotozip also includes circle-cutting attachement. If I were to attempt the cut like you are trying, I would use rotozip with that attachement and no table.
    Alex V
