Battery for HF Digital Caliper?
  • jstevens
    • 125
    • Ardmore, PA, USA.
    I need to replace the battery in my HF 6" digital caliper, but I can't find a store that stocks a battery that matches the number-letter code on the battery. If anyone can suggest a replacement battery, I'd appreciate it. Thanks in advance.
    Regards,
    John
  • golfmore
    • 227
    • Centennial, CO, USA.
    You may want to call their cust service.
    843-676-2603
    • rickd
      • 422
      Regards,
      John
      hi john,
      i took my hf caliper battery into the photo dept. of my local drugstore and got a replacement that works fine. it is an "Energizer A76". it wasn't the same as the hf number - but the store clerk said its the same battery and it works. these batteries are sold anywhere you can find Energizer brand.
      hope this helps.
      rick doyle
      Rick's Woodworking Website
        • 22104
        Regards,
        John
        That is a very, very common button cell and it goes by a whole bunch of similar numbers
        Silver Oxide chemistry
        SR44, SR44W, 303, 357, AG13, G13
        Alkaline chemistry
        LR44, A76, EPX76
        the silver ones will cost more and may last longer.
        Other than that you won't be able to tell the diff if its silver or alkaline.
        are some of the ones of the same size and voltage and will work.
        Shold be a piece of cake to find at Radio Shack (#23-104 or 23-105) or even the corner grocery store. The 357/RS23-105 are about .01" thicker and usually fit no problems.
        more equivalents:
        1131SO SR44 D357/303 SP357 SR44W V357 AG13 G13 A76 PX76 675 1166A PX76A A76-1 LR44H V13GA GP76A L1154 RW82.
        The silver ones from Radion Shack will cost about $3.50
        but you can find a card of 10 (probably Alkalines) at the local craft store for about $3. These are chinese made for flashing LED buttons and badges, no idea if they'll last 1/10th as long but they're only .30 apiece. You can also find cards of 10 cells on ebay ridiculously cheap for crafts and LEDs and Laser pointers (which often use 3 cells and cost under 10 bucks).
        • jstevens
          • 125
          • Ardmore, PA, USA.
          Thanks a lot, guys. I wasn't sure whether I could substitute a battery with a different "number" as long as the size and voltage were the same.
          Regards,
          John
          • jziegler
            • 1149
            • Salem, NJ, USA.
            Wow, good to see this thread, even though I just bought my caliper a couple weeks ago (and is has a spare with it). Conviently enough, that's the same type of battery that my SLR camera bodies use. Nothing more convient than only having to keep one type of battery around for multiple things.
            -Jim
            • maxparot
              • 1421
              • Mesa, Arizona, USA.
              • BT3100 w/ wide table kit
              RadioShack claims to be able to order any battery.
              Opinions are like gas;
              • Knottscott
                • 3815
                • Rochester, NY.
                • 2008 Shop Fox W1677
                At the risk of hijacking your thread just a bit, I bought an HF digital caliper last week. They've got a few versions of them....the one I got is the 47257. It seems to be great for the $17 (less 20%) price. Anyone else have this one, and what do you think of it?
                  • 22104
                  Has long been on the list of best buys from HF.
                  I own at least two of them.
                  Jim, the battery is probably the most popular button battery.
                  I have alarm clocks, calculators, cameras, thermometers, several calipers. laser pointers, laser guide for the miter saw, all using one or more of these cells, just off the top of my head. Just FYI it's a 170 mAhr Battery at 1.55V in the silver oxide configuration.
                  and the Alkaline version is only rated at 150 mAhr
                  BTW, it pays to shop around,
                  Office Max has the Energizer A76 for $0.99 and Buy.com sells them for $5.99
                  I'd go to Office max for an A76 and not pay $3.50 at Radio Shack!
                  After all the Calipers only go for around $16 now.
                    I like my HF digital caliper but am currently thinking a fractional dial caliper might be even better. No battery plus output in the fractional inch sizes I actually use. Now if I could just get one at HF pricing.... The cheapest I have seen is about $40. I do not know how absolutely accurate the HF unit is but it is plenty accurate enough for my woodworking.
                      • 22104
                      Its absolute accuracy is quite good. matches the absolute readings I get from an expensive Mitutoyo at work costing 10 times as much.
                      Also repeats perfectly to the same values.
                      I'm not sure if the battery life is so-so or probably its the cheap $0.10 chinese batteries I toss in it - maybe one day I'll start keeping track of battery life and then put a name brand battery in it and see if it lasts longer.
                      • wassaw998
                        • 689
                        • Atlanta, GA, USA.
                        Dustmight - I am not 100% happy with mine (same as yours). Mine has a hard time parking on a value, the numbers want to keep changing which make for some real frustrating measuring. Since I've never heard anyone else mention that, I guess maybe I got a lemon. Also, the original battery only lasted a very short time, but I am still on the replacement that came in the case.
                        Chris
                        • Andrew Benedetto
                          • 1071
                          • SoCal, USA
                          Walmart has a 3 pk of 357 duracell that is not that expensive. The silver oxide 357 is much better in life than the alkaline. I use that in both my Mitutoyo, and HF ones.
                          Andrew
