Screws for MDF
  • Andrew Benedetto
    • 1071
    • SoCal, USA
    Drwall screws are not as strong as true wood screws,the ones threaded but not tapered,like you said. McFeely web site has a comparison.I have been using the senco self drilling ones that go to my auto feed gun,pulling them off the strip as needed if I use a countersink type. they are square drive and galvanized and can countersink themselves by the cutting edges on the screw top. I usu. still countersink. I do still prefer the kreg jig for joints.
    Thanks for the technique description. I still do not know how you make MDF look so good,I really do not like the stuff,but it is flat and cheaper than ply.
    Andrew
    • jarhead
      • 695
      • Boynton Beach, FL.
      Here's another tip from woodworkingtips.com
      • MilDoc
        Thanks for all the advice! As a newbie who has never used MDF, I have two projects to use it in. Decided to purchase some confirmat screws for one (only took 24), and some deck screws for the other. I love to try a lot of techniques! I will drill pilot holes, and countersink top and bottom of the top piece. So, as Edison said, 99% perspiration (ie, try it!) and 1% inspiration!
        • GaryA
          • 365
          • Tampa, FL, USA.
          I just discovered these SPAX screws at BORG...they are awesome for MDF. I was getting a lot of aplitting as mentioned, and these do the pre-drilling for you with the tip. I was having a hard time findiung anyone (except McFeelys) that had Confirmat screws & bits. I dont see the need now...I'm sold on these! They were about $8-$9 for a box of 235 (1lb) #8, 1 1/2" (much less than the Confirmat)...highly recommend for MDF!!
          Gary
          • twilson
            • 18
            I'm building some cabinets using MDF. I bought SPAX screws specifically for MDF through Amazon.com. I have not encountered any splitting while using these screws.
            • GaryA
              • 365
              • Tampa, FL, USA.
              Yep... they've got them at my local Home Depot...FYI
              Gary
                Here's my tip on this resurrected thread. I use a countersink bit with an adjustable countersink. The depth of the hole is adjustable. They are available by number and/or size. I use mostly coarse thread screws that are threaded all the way to the head, they can be either a #6 or #7. A #8 screw is a little too large for 3/4", IMO. My tip is that when seating the screw don't do it fast. When the head gets close to the countersink hole, just bump tighten it slowly. As for the countersink/drill assembly, I use bits similar to these.
