Any way to hide the fund-drive header?
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Cool -- glad you all like the Stylish suggestion and thanks for the feedback!
    I should point out, though, that the code depends on the bt3Central.com site following a specific structure. (In this case, the first "tborder" table after the "pagenav_menu" section is hidden -- no matter what it is.) So if the site structure changes (e.g. Sam removes the fund drive part), then this code may need to change or be disabled as well.
    If part of the site suddenly disappears after an administrative site structure change (not common), then this may be the cause. Click on the Stylish icon at the bottom right corner of the browser window and select "Turn all styles off" to see if the add-on is the cause. If it is, just disable the style.
    (I'll add this part to the post with the style code.)
    • Alex Franke
      • Feb 2007
      • 2641
      • Chapel Hill, NC
      A little more fun with Stylish (by request)...
      These are helpful for small screens. The first one hides the top advertisement. (Be sure to disable Stylish before you click through to Woodcraft or Amazon!) The second one hides the main page header. Add them after the "#pagenav_menu" line.
      PHP Code:
      body > div:first-of-type { display: none }
      body > table:first-of-type { display: none }
        • 4715
        Folks ditto what Sarge wrote. As the other mods I'm a volunteer with somewhat limited powers although a bit more than them. I do want reminders from folks when there is an issue such as Sarge's never cashed check. I'm trying to get to an answer and a solution about that as well as the banner going away as per Ray's request from way back.
          I do want reminders from folks when there is an issue such as Sarge's never cashed check. I'm trying to get to an answer and a solution about that...
          That one is easy. Send all checks to me, I'll cash 'em.
          • RodKirby
            • 3136
            • Mao Shan TSC-10RAS
            +6th (7th, 8th?)
            As I recall, it used to only show during the fund drive...
            Downunder ... 1" = 25.4mm
            • jhart
              • 1715
              Back in January, I sent in my check for renewal, the check has been cashed, but the header still tells me that my membership has expired and to click "here" to renew. I have PM'd Sam twice about it, but no response or action???
              Would also like to see banner reduced, but don't use Firefox.
              • Bruce Cohen
                • 2698
                • Nanuet, NY, USA.
                Does Sam still exist. if so, someone should call him and tell him to shape up, this is getting real old real fast.
                Bruce
                Samuel Colt did"
                  My MO from January (?) has still not been cashed. I have had no word at all, so I'm just gonna sit and watch what happens.
