Tutorials section permissions?
    • 9568
    When I try to post a new tutorial, I get the following error...
    you do not have permission to access this page. This could be due to one of several reasons:
    1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    I am assuming this is a permissions change with the new software...
    Check again it should be fixed now.
      • 9568
      No joy, message with errors sent...
      • Sam Conder
        Woodworker Once More
        • 2502
        • Midway, KY
        • Delta 36-725T2
        Try it now.
        Sam Conder
        BT3Central's First Member
          • 9568
          Your submission could not be processed because a security token was missing.
          If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
          It's not happy yet...
            Have you logged out, cleared your cache, then logged back in and re-tried?
              Still broke for me too.... Will be working on it!
                It opens for me. Maybe you just have to be good looking.
                  Nope, that can't be it, 'cause it works for me, too...
                    It should open for all viewers. The problem is that the section is not accepting new posts. Unless ya'll are saying that you can create now posts in the articles section?
                    • Sam Conder
                      • 2502
                      • Midway, KY
                      • Delta 36-725T2
                      OK folks, its starting to look like a compatibility issue with the Articles plugin I purchased for the site and the new version of vBulletin. To be honest, I for got that the Articles mod was a purchased product and I let the maintenance agreement expire. I will re-up the subscription and will download and install the new version ASAP. Most likely Friday night or Saturday night.
                      Sam Conder
                        This is what I get when opening for new tutorials.
