Amazon Site support question
  • jbalders
    • Oct 2003
    • 298
    • Vienna, VA, USA.
    • BT3100 + Shopsmith
    Sam,
    I tried to do a search using the Amazon form in the "Support this site" area. It can't find something that I'm looking to buy. However, once I'm on the Amazon site, I search again and it finds it just fine.
    Does the site still get credit under this circumstance?
    I was trying to get the H5783 canister for Grizzly DCs, and no matter what terms I search under, the form on here won't bring it up.
    Jeff
    Jeff
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    If you used the search, and then it took you to Amazon but told you "not found" but then you searched again IN Amazon, it should be fine. Incidentally, I used the search box, chose to search in Tools & Hardware and entered H5783 and found the canister.
    Sam Conder
    BT3Central's First Member
    • jbalders
      • Oct 2003
      • 298
      • Vienna, VA, USA.
      Sam,
      I used the search with "All Products", so apparently it doesn't really mean "All Products". I figured if it couldn't find it with no restrictions, there was no sense in limiting the search.
      Thanks,
      Jeff
      Jeff
