Can't stay logged in????
  • dxcoded
    • Oct 2003
    • 89
    • nashville, TN, USA.
    • ridgid ts3612
    I have tryed to log on many times and it says it was successful but when it takes me back it needs to be logged in again???? Is anyone else having this problem. I am on a mac and am wondering if this could help in the problem? Sam any ideas?
    thanks
    eric
    eric may
    eric may
    The Safari web browser is behaving weirdly here, so I am using Camino. I.E. displays OK, but the 1 inch left column wants to take about 2 inches. On the Safari, the left column takes half the page. On Camino, everything displays beautifully. Haven't checked anything on my Compac PC yet.
    I will say that the column problem on Safari started on the 2nd day after the column was added, so I don't think it was the column or this forum.
    Hank
    • Sam Conder
      Woodworker Once More
      • 2502
      • Midway, KY
      • Delta 36-725T2
      Lee,
      Others are reporting the same Safari issue. I am currently trying to work on that. Luckily, Safari is based on Konqueror which is a KDE based browser under Linux. I am throwing together a Linux machine so I can view the forum under Konqueror and se if I can figure out the problem.
      Sam Conder
      BT3Central.com Admin
      Visit www.samconder.com for a peek into the life of the woodworking nerd who created BT3Central.com
      Sam Conder
      BT3Central's First Member
      • Sam Conder
        • 2502
        • Midway, KY
        • Delta 36-725T2
        Eric,
        Try deleting your cookies and let the forum place a new one on your machine.
        Sam Conder
        Sam Conder
          Thanks Sam, for checking on the Konqueror/Linux issue. I go back and forth between three browsers regularly, as none are perfect in all the diverse websites that I access - (multi-lingual browsers are a necessity).
          Hank
