Adding more security.
    • 9568
    As some MAY remember, years ago, the house next to me got rented out to some not so great renters, and I became very security focused after things started walking away...
    Well fast forward to this past month and my oldest brother gifted me his now orphaned Wyze Pan Cam V3s. He went with a camera setup that doesn't have a subscription even though the Wyze subscription is relatively inexpenisve...
    So between the gifted Wyze Cam Pan v3 that has auto tracking / pan / tilt, I also set up my Wyze Cam V3 that had been previously watching my fence line in the side of the house, now replaced with a Wyze Cam Battery with solar panel (had problems sourcing power for the cams without solar...).
    Mind you I live in a decent neighborhood, but that's the problem. Thieves etc... from out of the area tend to stalk neighborhoods like mine since the PD that recognizes them is 2 towns away.
    I hate th contribute to a surveillance state, but I can limit the monitoring range to the edge of my property. So since I am the one monitoring IN and ON my property, we should be good to go.
    I have a couple of Ring devices left. A Ring Spotlight Cam wired, a Ring Doorbell cam, and a Ring Floodlight cam. I am trying to get off of Ring as the lag between event and notification is huge, like 30 seconds... WIth the Wyze it is almost instantaneous...
    I have the Wyze floodlight cam to replace the ring that is basically the motion activated floodlight fixture typically seen in backyards and driveways but with a camera.
    So to protect the shop itself I have the following coverage.
    1 cam in the rear of the shop pointing toward the roll up doors
    1 cam in the front of the shop pointing to the man door from the house.
    1 cam outside down the driveway between the roll up doors.
    Door contact sensors at each door
    85db siren
    Security keypad.
    It stinks when the behavior of others makes you have to take security steps like this...
  • Jim Frye
    • 1364
    • Maumee, OH, USA.
    • Ryobi BT3000 & BT3100
    I agree. The neighbor behind me has cameras but all they pick up are the coyotes that roam through at night. Guess we are lucky.
    Jim Frye
    The Nut in the Cellar.
      • 9568
      My cams haven't picked up anything other than package deliveries, and the kids next door cutting through my yard to get to school since the idiot on the other side moved out...
      When I first set up, I was on a Smartthings by ADT setup with cameras and monitoring. The idiot had a friend decide to park directly in front of my house, in plain view of the camera and was less than discrete about their use of certain flamable substances. ADT flagged it and called the local PD, the dude got arrested. My neighor was VERY unhappy and thought I made the call when I pointed out the Security monitored by ADT signs all over the yard, he turned around, stomped off and 2 months later they were gone.
      The next and current renter is a decent guy, although his little yappy dog is a pain in the tail...
      The kids from the house on the other side have been using my back yard since the fence was blown over during last years hurricane and I haven't rebuilt it yet. It goes straight back to the creek behind the house and they use it for a shortcut to school...
      I recently got a farm jack, with a fence post choker and will start ripping the remaining part of the fence and posts out, double check the survey pins and lay out for the new posts and beams, and just grab fence pickets as I go... Start with the side between houses to end the cutting through...
        • 9568
        Not 100% set up yet, but so far I have...
        Wyze cams installed.
        3 Pan and tilt auto tracking cameras
        1 wired fixed position camera with a tiny floodlight.
        2 solar / battery powered fixed position cameras with tiny floodlights.
        Wyze cams not installed and the reasons.
        2 Pan and tilt auto tracking cameras. Missing the mounting screws for the base. 1/4-20 with a stupid wide flat head. Waiting for tomorrow to go to Ace Hardware.
        3 wired fixed positon cameras. No tiny floodlights. Missing power cables, ordered on Amazon pending delivery tuesday.
        Wired in full size LED light fixture with camera. Too much rain to install this weekend.
        Pending acquisitions to finish conversion from Ring to Wyze.
        Full size LED light fixture with camera + their mounting box / power cord. Basically a round junction box sort of thing with an extension cord coming out of it. This is to replace the ring unit at the front of the house.
        Wired video doorbell.
        Once I am fully up on the Wyze gear, I can drop my Ring subscription plan which should save me over $100.00 / year...
        Progress is being made!
