Plunge drilling (jig) for Bench Dogs - Part II
  • hermit
    • 379
    • Somerset, PA, USA.
    I'll try from work as well.
    Todd
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    All the bits:
    In order to prevent movement during drilling (and clamping), I glued 180 grit sandpaper on the stretchers, base and the “zero edge fence” (ZEF) – what other forum lets you dream up your own acronyms?
    Drilling Reach from an edge (without ZEF) is 4-1/2” thru 13” – center to center. With ZEF I can drill right up to an edge.
    This Pic shows it all together (including the ZEF) – set up to drill right on the edge of the bench. Not obvious, but the base has all 4 brass “clamps in place – still enough room for the quickgrips.
    This next pic was taken especially for Mainemarc – he will tell you why.
    Part III coming – Drilling the holes!
    Downunder ... 1" = 25.4mm
    • Hoover
      • 1273
      • USA.
      I've gotta go pop some popcorn!!! This is great!!! [)][)]
      No good deed goes unpunished
        • 10453
        Rod, have you made the move to off-shore manufacture of your jig designs? I'm quite sure this wasn't actually made in your shop....there's no MDF used in the construction!
          Internet Fact Checker
          • 21031
          What? Hey Rod, Where is the indexing peg so that you can index this hole exactly the same distance from the last hole?
          • w973
            • Nov 2004
            • 42
            • Nevada, USA.
            I'm inpressed by the theaded inserts. Could you share the brand/type? How are you going to connect to your DC?
            Walt
            • bruffc
              • 149
              • Gardner, KS, USA.
              • BT3
              I'm not Mainemarc but I did notice that all the screw heads are lined up
              Bryan
              • Mainemarc
                • 673
                • Portland, ME, USA.
                As I recall, I used a bit brace and a 3/4" (thats 19mm to you, Rod) auger bit to drill my bench dog holes. I had the workbench outside in my driveway, I sat cross legged on top of it and finished the job in what? Maybe 20 minutes.
                Well, someone has to chart the other end of the A/R spectrum.
                Marc
                • RodKirby
                  • 3136
                  Pappy - Please have an even closer look
                  • RodKirby
                    • 3136
                    Walt
                    I get my inserts from woodhaven.com. Attached to a bolt and then hammered in. If you slightly countersink the pilot hole they seat very well.
                    http://www.woodhaven.com/detail.aspx?ID=371
                    I have a plan for DC!
                    • jnesmith
                      • 892
                      • Tallahassee, FL, USA.
                      MDF edge-banding?
                      John
                      • RodKirby
                        • 3136
                        Yes John. 1/8" MDF
                        They are there to stop the base from "swinging" as it's moved along the slots.
                        • final_t
                          • 1626
                          Okay, aside from the ungodly clean shop, Rod has mad camera skilz, too.
                          Probably been asked before - what make/model are you using? Even with a tripod mount and timer release, my pics come out lousy. But give the same camera to the youngest, and all is great.
                          • KenBurris
                            • 439
                            • Cincinnati, OH, USA.
                            Final_t,
                            according to this thread,
                            http://www.bt3central.com/forum/topi...TOPIC_ID=17474
                            Rod uses his Finepix S5000 with 10 x Optical zoom
                            (and MDF carrying case)[)]
                            Ken in Cincinnati
                            Pretend this line says something extremely witty
                              • 10453
                              My most humble appologies, Sir Rod![V] I missed the MDF edge on the rails.[B)]
