Shop Progress
  • jussi
    • 2162
    Shop Progress
    A few weeks ago I started installing laminate flooring in my shop. After several delays I finally finished and this weekend I moved in most of the tools. Alot of the larger tools were stored outside under a covered carport. And while no rain got on them, I'm guessing the morning dew was enough to cause some surface rusting. So I had a bit of rust removal on my plate.
    This is, what I affectionately call, the shop the Craigslist built. I've had the tablesaw and spindle sander for several months now but just turned them on for the first time today because I didn't have 220 until now. The tablesaw is a beast and took 4 of us to carry in. But now that it's in the shop, I can easily move it with the built-in casters. I wasn't able to use the casters outside because the ground was too bumpy outside. Putting the saw back together and tuning it up took almost a whole day in itself and I'm still not quite finised. I still have to adjust the fences straightness but I don't think that will take long. I've only made some test cuts but I'm loving all the features it has so far. I'm using the stock guard for now but I eventually want to use my old excalibur overhead guard. I just need to make some kind of bracket to have it ceiling mounted since the right side of the saw has a router table now and he left side is too close to the blade. I initially wanted to mount a jessem mast-r-slide to it but couldn't bring myself to hack up the tube and rails. I wanted a more direct path for the dc run to the tablessaw this time around so I dug a hole and made a cover for it. I then attached ducting to the cover so I could take it apart if it ever got clogged. I still have alot to do but it's a start. If I make anymore significant progress I'll update here.
    That looks really nice. How does it feel to walk on wood-ish floors over foam compared to concrete?
    • jussi
      • 2162
      Alot better. It's the main reason I put them in. I was in a shop some years back that had them installed and I knew I eventually wanted them in my shop. It's an mdf core so even without the foam it gives some cushion. Before this I covered half the floor with that interlocking foam tiles which was a hastle since alot of my tools are on casters and I had to move the tiles out of the way to move the tools. I will probably keep a few and just use them on key spots where I know I may be standing for a long time.
      • wardprobst
        • 681
        • Wichita Falls, TX, USA.
        • Craftsman 22811
        Wow, looks good, glad you are "in the dry".
        DP
        www.wardprobst.com
        • Cochese
          • Jun 2010
          • 1988
          That looks really great. You used foam? What depth?
            • 3791
            Nice looking floor! I know you are glad to be back in the shop for other reasons than working on it. When you figure out where the right spot for the foam mats please let us know. Is that a new Powermatic?
            capncarl
            • jussi
              • 2162
              I just went with the best reviewed on Amazon and got this. Which is 3/32" thick. Prob should have looked around a bit more and gotten the 1/8" thick type. But I'm still really happy with it and it MUCH better than my old wavy, unforgiving concrete floor.
              • jussi
                • 2162
                capncarl
                Thanks. I'll probably put one near the tablesaw and router table for sure as I'm usually standing in front of those machines for long periods of time. Not sure where else just yet.
                The saw, PM2000, is new to me I got it on craigslist mid last year for a song and replaced my trusty craftsman 22124 zipcode saw. I want to mount an overhead guard but can't use the Excalibur set up as it will block my router table. I'm thinking of just using the guard and making a ceiling mount for it. Saw this online and want to adapt something like it.
                Excalibur also makes a ceiling mounted version but I'd have to order the whole guard. But it does give me ideas on a mount
                  Nice floor Jussi and the table saw looks like new is that a PM2000?
                  Did you get that on CL as well I have seen a few here advertised but they still seem a little pricey. I always wanted a PM but not sure my small shop would fit such a beast. If I ever retire my BT I guess I may end up with one of the smaller saw stops as LOML thinks they are a good idea.
                  I also see you have the 50-760 DC in the middle of the shop still with the stock bag. I found that mine does a great job but it also distributes the fines all over everything. When I was working in my garage with the door open its was OK but now I have moved to an enclosed shop I have decided to install it outside. I see you have a lot of DC plumbing but have you considered possibly creating a DC closet to at least minimize the fines issue?
                  • jussi
                    • 2162
                    Yah the PM2000 is used and I got it from CL. The previous owner took really good care of it and didn't use it much. It came with a mobile base (aside from the built in), a router table set up and a trion router and lift, and few other accessories. I've always wanted a saw with a riving knife and the newer, more effecient dc and when this one appeared for 70% off retail I pounced. Even though I didn't really have the room or more importantly the power (110 only) to use it. Short of a Sawstop showing up for a great deal I think this will be my final tablesaw.
                    Yah the dc does miss alot of the fine dust. But fortunately I work with garage doors open so that helps. I use my larger compressor and go throught the walls and ceiling and blow out the fines laying around once every couple of months. The Thien separator does a great job of getting the larger stuff but (as expected) most of the fines get through. I will probably will order a canister filter soon, probably a wynn. But the ultimate goal is to get a real cyclone. The down side of those is the cost and size. JDS makes a really nice one that's quite compact (when compared to other cyclones) and would solve my size problem. But of course there's the $1500 price tag to deal with.
                    I hadn't really thought of a dc closet. Space is a premium and I doubt I would have the space but I'll look into it and see. Thanks for the suggestion.
                    • Cochese
                      • Jun 2010
                      • 1988
                      Ahh, I was thinking of rigid foam. I wonder how that would work.
                      • jussi
                        • 2162
                        Not sure but I'm thinking if it's too thick and you roll something heavy over it, especially the seams, it might snap. Also if I'm not sure the foam itself is a vapor barrier so you would still have to add that.
                          If you are in the garage do you have an outside wall and room to potentially create an external closet? Thats my plan and as you work mostly with the doors open you will have no problems with the make up air issue. I should get mine started in a week or two and you will see how it goes.
                          • jussi
                            • 2162
                            There's about 5 ft from the wall of the garage to the neighbor but unfortunately it's taken up by wood storage and a small shed. Plus one of the main reasons I have the dc in the middle is to minimize the ducting length. I'm not sure what the dust collection will be like if I have significantly lengthen the runs. But I'm curious to see your set up when you get it up.
