Cochese,
I use the router kit for my 21829, and keep a dedicated router in it, in addition to having build a separate router table, also with a dedicated router in it. The router kit will get you quite a ways, especially if you build an auxiliary router fence to mount to the rip fence, instead of using the kit version - mine includes a built-in port for my shopvac.
When I started routing larger pieces, and then wanted to do raised panels, the router kit was too small, so built the bigger table. My 21829 is still on the mobile stand, but if it weren't, I'd probably be looking to copy the on-saw custom tables like JRs.
). I have a homemade on my Ridgid 3650, homeade fence and a Woodpecker insert. FOr DC I use solely a shop vac just behind the bit and attached to the fence. I used to have an extremely low tech, loose 1x1 brackets so that I could sling a small, plastic waste basket under the router. When I determined that the vac was getting nearly all of the dust I eliminated the basket in favor of better air flow.
