Electrical Question
  • williwatt
    • Aug 2007
    • 150
    • Springfield, TN
    • Sears 21829
    Electrical Question
    I have a 12" RAS that has been sitting idle waiting for me to move it to an outside basement wall where there is a 220v receptacle. I am now thinking I would like to leave the saw where it is and run a 220v line to it.
    My question is: Is there any problem codewise or other restriction on installing a 220v receptacle in the unfinished basement ceiling? The saw is located in the middle of the room so I can't put a receptacle on the wall without using a long cord.
    Another solution would be to rewire the saw back to 110v as it was when I bought it, but it runs better on 220v.
    Any suggestions?
    I knew of no reason you couldn't do that, but to be sure I ran the question by our electrical engineering consultant, who makes his living with the NEC at hand. He says no problem, but suggests you consider a twist-lock receptacle so the plug won't accidentally fall out.
      • 22109
      that's a good idea (Twist-lock); that was my first thought.
        I would wire it to continue to run on 220V.
        • jackellis
          • 2638
          • Tahoe City, CA, USA.
          The electrician who wired our home has suggested I use a 220V extension cord for my saw, which will sit in the middle of a 22x22 shop that has 220V receptacles on one wall.
          I have locking plugs and receptacles for both of my 220V tools.
