Air Line System
    Air Line System
    Saw this system for running airline. It's a quick connect, and easily moved if desired. A lot less of a hassle than rigid piping.
  • thrytis
    • 552
    • Concord, NC, USA.
    • Delta Unisaw
    Harbor Freight sells a similar system as well.
    Eric
      At first glance I think "leaks." Anyone tried one of these?
      • os1kne
        • 901
        • Atlanta, GA
        Thanks for the links. I've been considering doing something like this in my garage, but using air hose and copper T's and pipe for the drops. Something else to consider...
        • Tom Slick
          • 2913
          • Paso Robles, Calif, USA.
          • sears BT3 clone
          I've used that type of tubing and push lock connectors quite a bit, they don't leak and are extremely easy to work with.
          I wouldn't hesitate to set up a system like that but it could be expensive, more so than copper.
          • thrytis
            • 552
            • Concord, NC, USA.
            • Delta Unisaw
            I've seen a couple people say they've installed them and haven't heard about leaks. I have for black pipe and copper, though i'm sure there are a lot more people who have installed those than the nylon tube system. A comment from an actual user and a link to another can be found at Garage Journal.
            Eric
            • dewi1219
              • 307
              • Birmingham, AL
              Wow, that HF setup looks like a great deal. I have looked at the Garage Pak aluminum setups before, but they were prohibitively expensive. Copper was my next choice, but it would involve a lot of sweating (the copper and me!). The HF kit looks like it would go up in no time.
                We use these type of systems on multi-million dollar robots at work running
                90-100psi. They work great. It's really nice to not be physically confined
                because of rigid tubing like iron pipe. I guess you can think of it like PEX
                tubing for air instead of water. They sell the connectors at McMaster-Carr,
                too.
                We usually run 1/8" or 1/4" tubing for most of the system which doesn't
                require high CFM.
                I have found, though, that if you need to disconnect the tubing, the tubing
                develops a permanent crimp in the end which will cause leaks when
                reconnected. I usually snip off that little 1/4" to get to some fresh tubing.
                The HF package includes a tubing cutter.
                  That's what I like about it that it installs easy and can be moved easily.
                  • fastfoodkills
                    • Jan 2008
                    • 89
                    • Saugus, CA
                    • BT3000 bought in Y2K; Replaced w/ Steel City cast iron 3 HP
                    Thats a great idea. I've been considering the copper pipe now that the prices have finally dropped a little, but sure like the idea of a quick easy install. Will have to plan a project soon that includes containing the compressor noise as well as an airline system. Thanks for sharing this.
                    • Tom Slick
                      • 2913
                      • sears BT3 clone
                      As an alternative there are push lock fittings for copper if you'd prefer copper but don't want to solder. The push lock fittings are currently used with water lines. It is an expensive option but they available at the local hardware or plumbing store.
                      Flexible lines for air supply can have issues with sagging which allow water to gather in the sag which is never good. The flexibility of these airlines makes for easy installation but it also makes it easier to make mistakes in system design.
                      A properly set up air supply is always pitched toward the source or towards a drain so the water runs back to a place where you can purge it. Another caveat is to never tap into the bottom of the supply line, your tap should always point up and make a "U" to go down. Following these basic rules can improve compressed air quality significantly and lessen the dependence on filters for "dry" air even in a small shop.
                      • drsung
                        Handtools only
                        • Dec 2007
                        • 4
                        Anyone try the harbor freight variety of this yet? I am thinking of picking up one on the Harbor Freight New Years day 25% deal.
                          Do you have a link for HF?
                          • wardprobst
                            • 681
                            • Wichita Falls, TX, USA.
                            • Craftsman 22811
                            http://www.harborfreight.com/cpi/cta...emnumber=66747
                            DP
                            www.wardprobst.com
                              Thanks for the link. Some of those parts sure do look similar.
