I have to drag a hose around my shop which creates a safety hazard. This looks like a nice idea and the HF version is reasonably priced.
Air Line System
I purchased the Rapidair garage kit clone from HF and I found it just as advertised, a very nice quality home shop system. The air line tubing is rather stiff and is difficult to try and uncoil. My experience was I had to use a clamp at least ever 48 inches, 36 inches would be better, to retain the tubing. The kit has been installed about three weeks with a less than average use and all it well!Comment
Very cool... I've been procrastinating about installing an air system in my basement shop area for a long while... that system looks like it just might get the nod.
The thing that worries me a bit, as mentioned in one of the threads linked to on another site is the parts availability down the road - at least from HF. Also... if you want to expand your system or use a non-standard configuration or just have to replace parts... how hard is it to find extra pieces-n-parts? Will the Rapid Air parts interchange with the HF parts?
Looks interesting otherwise.
MonteAll right, breaks over. Back on your heads!
My WAG is that since this is tubing which is sized industry standard Outside Diameter and the fittings are NPT threads then you should have 100% interchangability....
Monte
I find the anti-HF statement on Rapid-air's website comical at best. This style of airline fittings have been used for years (15+ that I know of) and I doubt that Rapid Air was the first. I'd give them the benefit of the doubt that they were perhapos the first to market a kit for the home shop application.Donate to my Tour de Cure
Returns: "Pack of 10, 24 grit 4-1/2" Industrial Aluminum oxide Grinding Wheels for Metal"
Downunder ... 1" = 25.4mmComment
Rod, this is an old thread and the air line system has been removed from the HF website. I posted this thread today because it has been marked down in my local store. If you go to the HF website and search for "66747" (the item number for the air plumbing kit) the search returns a 14 piece air accessory kit.Comment
