Boeshield staining?
  • dlminehart
    • 1829
    • San Jose, CA, USA.
    Boeshield staining?
    Anybody here use Boeshield to protect their cast iron tools from rust? I've read that it stains or discolors them. Is this a subtle or significantly obvious effect? Is it reversible? Is there a rust protectant that doesn't do this? I've read about something called something like XCorrosion that is supposed to do a better job without discoloration. Anyone familiar with it?
    - David
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    I don't find the discoloring to be anything more then a deeper grey iron color. it doesn't stain as if the table turns into 5 different shades of red. it isn't really noticeable once the entire surface is covered.
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      I personally could care less about any staining, however I like Bostik Topcoat better than Boeshield T-9. Easier to apply, lasts longer, works better in cold weather (had problem with T-9 drying).
      • p8ntblr
        • 921
        • So Cal
        • Craftsman 22114
        Not from T-9 but the Rust Free discolors pretty significantly. It's an acid and etches CI. I had to use a ROS and WD-40 to take it off. You don' really need to as it doesn't really affect the performance, but I'm just anal about that short of thing.
        I personally still get rust using T-9 and wax and have to redo the process 2-3 times a year. But then I leave near the coast, so I'm guessing the air corrodes it faster.
        -Paul
        • p8ntblr
          • 921
          • So Cal
          • Craftsman 22114
          I've heard good things about a product called TC-11. Anyone use this?
          -Paul
          • ironhat
            • 2553
            Where did you manage to find the Bostik Topcoat, Jeff? Please don't say Woodcraft in Harrisburg.
            Blessings,
            Chiz
            • Jeffrey Schronce
              • 3822
              • York, PA, USA.
              • 22124
              Little more north . . . Grizzly in Muncy.
