Power Cord Tell-Tales
    For safety reasons, a power tool should always be unplugged before changing its blade or bit. But the power cords of benchtop and stationary tools are often routed behind benches, cabinets, and other tools, making it difficult to figure out which cord belongs to which machine.
    I solved this problem in my shop by putting two color-matched zip ties on each cord: one near the tool's motor or power switch, the other at the plug (see Photo A). By using different color zip ties for each machine in the same area of the shop, I can tell at a glance which plug I need to pull before servicing a particular machine (see Photo B).
    But you cannot be too careful. Even though this simple system works remarkably well, I always try the switch on the tool to verify that it actually is unplugged.
    Very good idea, I like that. Nice pictures too.
    • jhart
      • 1715
      Like that idea also Larry. Thanks
      • TheRic
        • Jun 2004
        • 1912
        • West Central Ohio
        Great idea Larry!!!
        Ric
          • 22034
          That's a good idea Larry, we've used something like that for other wiring but I have not ever considered it for power cords in the shop.
          Getting a variety of ty-wraps in different colors may not be easy...
          another option would be to use vinyl tape - I've seen small packs with four colors that could be used. If you have a lot of machines but limited colors, use two at a time. N colors gives you N-squared combinations of two, just keep the order right!
            I should have mentioned that. These are readily available at Lowe's, HD, HF, and probably other places ... typically in a plastic jar containing ties of varying lengths and colors. I think mine came from HF.
              If you haven't done it yet, send this in as a tip to one of the wood mags.
              Maybe you'll get top pick!
              Great idea!
              Paul
              • ejs1097
                • Mar 2005
                • 486
                • Pittsburgh, PA, USA.
                Good saftey tip and reminder. Sometimes its easy to get lax on tools like the DP, etc that lull you into false security.
                For all my plugs behind my TV and computer I used a silver sharpie and wrote on the plug what device it is for (no more cord following), think I'll do the same in the shop.
                Eric
                Be Kind Online
                • gad5264
                  • 1407
                  • Columbus, Ohio, USA
                  • BT3000/BT3100NIB
                  Great idea!
                  Paul
                  Great idea Larry and I also think you should send this to the WW magazines. It couldn't hurt to try.
                  Grant
                  "GO Buckeyes"
                  • big tim
                    • 546
                    • Scarborough, Toronto,Canada
                    • SawStop PCS
                    Great idea!
                    Paul
                    Definately worth a try, Larry. FWW paid me $100 for somthing I sent in recently.
                    Tim
                    • gerti
                      • 2233
                      • Minnetonka, MN, USA.
                      • BT3100 "Frankensaw"
                      Great idea, yet so simple! I'll be doing that!
                      • Brian G
                        • Jun 2003
                        • 993
                        • Bloomington, Minnesota.
                        • G0899
                        Good idea.
                        I agree that you should send it in. Some guy won a top tip by noting that he used luggage padlocks in power cord ends to prevent his kids from plugging them in. Your idea is just as good.
                        Brian
