I know that using your router to re-surface something is not a new idea, but if you have your router mounted on the BT3 accessory table and the piece you want to re-surface is not too wide, this might work for you as well as it did for me. I had two cutting boards that needed to be refinished, the boards were cupped as well.
I used strips if MDF as rails to slide the accessory table mounted router back and forth on. When I couldn't go far enough to the right,
I simply rotated the table 180 degrees to finish. (I know the picture shows that I haven't finished the left side yet.)
Cutting board finished. I completed the job using my ROS.
I used a straight 3/4 bit so it took a while, but I was pleased with the outcome. I originally started the job using my belt sander with a 50 grit belt, but didn't seem to get anywhere. the boards were made from hard maple. Then I got this idea and it worked great.
Tim
Tim
