Sow's Ear Update: 05/15/07
    A couple weeks ago, I posted some pictures of the interior of the larger building into which I'm in the process of moving my shop -- see Turning A Sow's Ear Into ... Something Better. The place was one heck of a cluttered-up mess, as shown in this, the second picture from that thread:
    We'll call that image Before. Here's its After counterpart, taken from approximately the same vantage point. Quite a change, eh?
    As the picture above shows, the tool layout was complicated by a row of pipe columns down the centerline of the building (a two-car garage; the columns are between the two bays). They did, however, provide a convenient place for dust collection drops (already installed, obviously) and power drops (not yet in place when these pictures were taken) for the various tools clustered around them. I spent many, many hours with our CAD software juggling the arrangement until I found the one that seemed to work best. The column nearest the overhead doors is where I chose to place the jointer, band saw, and dust collector.
    For now, the miter saw is sitting on an old counter structure that was being stored in the space when I moved into it. The first big project in this new shop will be to build a large miter saw station and storage unit, somewhat similar to the one in The New Yankee Workshop. The bench will extend along this entire wall; the laminate leaning up against the wall is earmarked for its countertop.
    The only two tools in the shop on mobile bases are the band saw and thickness planer. The band saw can be used right where it is with workpieces up to around six feet long; if I need a little more infeed room, I can rotate the saw about 20 degrees counter-clockwise and increase that to nine feet, by angling the material into the corner of the shop. (The band saw must also be so rotated to obtain the maximum available infeed clearance for the jointer.) When the thickness planer is needed, it will get wheeled up to a position next to the scroll saw, just visible in the foreground at right. Here it will have about nine feet on clearance on both the infeed and outfeed sides.
    Finally, here are two views of the Otter-built "Ryoborghini" BT wide/mobile base that has served me well as my primary router table for almost three years now. The first picture looks past the drill press toward the assembly corner of the shop. The second is taken from the opposite side and shows the dust collection hookups for the fence and router box.
    At this point the new digs are more or less fully operational; all the big stuff is moved in and ready to go. The two most pressing jobs left are to install a new electrical subpanel and get the new circuits I've installed permanently connected; and to figure out where and how to store the seemingly endless assortment of small items -- glues, finishes, sandpaper, handheld power tools, blades and bits, etc. -- that it takes to run even the smallest woodshop. I figure the panel installation will take a couple hours. Solving the storage puzzle might well take months.
    I'll post more pictures when progress warrants; thanks for looking!
      Looking very nice. I really like the green PVC. It makes me think of my Inca tools.
        That's very nice.
        I think I hear your neighbor saying she needs the space back.
        • siliconbauhaus
          • Dec 2006
          • 925
          • hagerstown, md
          very nice setup you have there Larry
          パトリック
          daiku woodworking
          ^deshi^
          neoshed
          • ironhat
            • 2553
            You *definitely* need more clamps - LOL!! Really sharp set up. Nice job.
            Chiz
            Blessings,
            Chiz
              That's turning into a real nice shop, Larry. You didn't get rid of the woodstove did you?
                That looks like a very cool place to spend a few hours. Nice!
                • TheRic
                  • Jun 2004
                  • 1912
                  • West Central Ohio
                  Looking good!! I think you need more MDF in there, then you can give Rod a run for his money.
                  Ric
                  • docrowan
                    • Mar 2007
                    • 893
                    • New Albany, MS
                    Shop looks fabulous!
                    Thank you for settling something in my mind with your "before" picture. I had always toyed with the idea of heating a shop with one of those HF cast iron wood stoves. I knew it probably wasn't real smart to have a fire burning in a small space that generated lots of sawdust, but seeing the old one in your before picture really helped my decision to stay away from that.
                    - Chris.
                    • goslin23
                      • Feb 2007
                      • 233
                      • Richmond, TX
                      • Rigid TS3650
                      It's quite a change there, I like what you have done.
                      If it ain't one thing... It's 12 @#$%ing things!
                      • Jeffrey Schronce
                        • 3822
                        • York, PA, USA.
                        • 22124
                        Its just the improved lighting fooling everyone.
                        Man I love the way you clustered the tools around the DC. Great layout!
                        • Jeffrey Schronce
                          • 3822
                          • York, PA, USA.
                          • 22124
                          Please tell me you did!
                          • Jeffrey Schronce
                            • 3822
                            • York, PA, USA.
                            • 22124
                            Oh no! This is a common law easement if I ever saw one!
                            • Duff
                              • 164
                              • San Antonio, TX
                              • Enco 12" RT
                              Lighting alone made a HUGE difference...Very nice!
                              Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
