HF DC and Jet Canister
  • newood2
    • 600
    • Brooklyn, NY.
    Does anyone know if the Jet 708739 Canister Filter can be fitted on the HF 2hp DC?
    Seem like it's the most reasonable priced canister filter right now. $178.09 including shipping from Amazon.com.
    Howie
    • 22053
    I don't have the Jet canister. I have the Grizzly.
    They both are 20" diameter and so should be close to a fit. The Griz has a rubber skirt (where have I heard that before?) that hangs over the outside of the ring. You put a strip of weather strip gasket on the outside top of the ring. And tighten the metal buckling strap over the skirt to seal it.
    IIRC, the jet comes with a new ring, but it may not be necessary. The Jet canister has a rigid outer skirt and it attaches with a number of knobs with threaded studs to the ring, by clamping pressure. I imagine but don't know for sure that there's a gasket of some sort between the canister and ring.
    So I can say for sure the Griz fits easily. But right now its $8 more. Might be worth it for confidence. And not having an extra ring to trip over.
    http://www.amazon.com/Grizzly-H5783-...6?ie=UTF8&s=hi
    Actually this picture does not show the skirt much at all. It's about 3" tall.
    I note they've also changed the rating to 1 micron from 2 it used to be. changed the material or just changed the spec? Who knows.
    • maxparot
      • 1421
      • Mesa, Arizona, USA.
      • BT3100 w/ wide table kit
      Howie
      The paper/poly kit from Wynn Environmental is only $90 for the HF 2hp.
      Opinions are like gas;
      • Hoover
        • 1273
        • USA.
        Here is a link to the Wynn site plus a parts list to make it happen: http://www.wynnenv.com/9e300bl_conversion.htm
        No good deed goes unpunished
        • ragswl4
          • 1559
          • Winchester, Ca
          • C-Man 22114
          Another link to Wynn, I don't think you have to do any mods to the HF DC if you use this filter. http://www.wynnenv.com/35A_series_cartridge_kit.htm
          RAGS
          Raggy and Me in San Felipe
          sigpic
          • coach
            • 317
            • Forney, TX.
            • Powermatic 66
            I tried this a couple of months ago, and the filter is not an exact fit. I can't remember if the filter was too large or small for the HF doughnut. However, the kit comes with a new ring. The only thing you would have to do is rework the mounting holes in the JET doughnut to fit the HF stand-off legs.
            OTOH, I decided to not modify the HFDC, and just sell it. I then replaced it with the JET 1100ck.
            If you're not living on the edge, you're taking up too much space.
            • newood2
              • 600
              • Brooklyn, NY.
              I did some digging and these are the available canister filters I found that could be a possible fit for the HF DC.
              I’m leaning towards getting the HF94278 as best buy for my purpose.
              Now if I could only get an online coupon.
              Grizzly H5783 1 micron, 19 5/8”dia X 23 5/8”H, no plastic bag $211.70 shipped
              http://www.grizzly.com/products/H5783
              PSI #DCanister2 1 micron 19 ½”- 20” X 24”, 1 plastic bag $194.00 shipped
              http://www.pennstateind.com/store/dcanister2.html
              HF 94278-0VGA 1 micron, 20 ¼” X 25 ¼” 3 plastic bags $181.98 shipped
              http://www.harborfreight.com/cpi/cta...emnumber=94278
              JDS 16002. 1 micron. No more Info. $179.99 shipped
              www.amazon.com
              Jet 708739. 2 micron. No more info. $178.09 shipped
              www.amazon.com
              Wynn 35ASeries. 1 micron. 17.5” X 23”, 3 plastic bags. $144.00 shipped
              Wynn 9E300BL conversion kit. .5 micron. 12 ¾” X 34” $94.00 shipped
              Thanks everyone
              Howie
                I've got the less-expensive Wynn filter. It works great. It does not have the beater/cleaner thing, though. It installed easily and I have no complaints.
                Their web site shows it being installed on the HF DC.
                • maxparot
                  • 1421
                  Ditto That!
                  Finest filtering and least espensive of that list
                  • newood2
                    • 600
                    • Brooklyn, NY.
                    I dont have the ceiling height for the $94 Wynn. I know it's a good filter but it's at least 10" taller than the others.
                    Howie
                    • maxparot
                      • 1421
                      Howie
                      The spun poly filter from Wynn is shorter and still cheaper than the others. It's also washable! It is said to be a lifetime filter because of that fact. Although my thought is with a little care the others would last a lifetime for a small shop.
                        That doesn't seem correct to me. I just went out and measured mine. It's 21" from top of the green part on the DC to the top of the filter. Looks pretty much like the others to me.
                        • maxparot
                          • 1421
                          JR is correct I just checked the Wynn website both of their filters for the HF 2hp DC are 17.5" diameter and 23" tall.
