DC vent to outside
  • mikel
    • Jul 2006
    • 202
    • philadelphia
    • bt 3100
    DC vent to outside
    I want to hookup grizzly 1hp two bag Dust Collector I have sitting here all ready. It came from my old shop and now I want to use it in my basement shop. I really want to vent it outside. There is are windows on three sides of the shop area. the space is 20x35 but has the house gas furnace and gas hotwater heater. I use a shopvac now. What is the safest way to do this or should I just sell it and get a good hepa shopvac.
    what should I search for to see if this has all ready been discussed?
    thanks
    ...michael
    It has been discussed before, the biggest problem is you will be pumping 1000-1200 cfm of airconditioned or heated air to the outside, somewhere else in your house
    1000-1200 cfm of un-conditioned air will be sucked into your house.
    If your house is real tight then the DC will be choked down and not work well, if your house is leaky then you will be faced with much higher heating and cooling expense.
    I'm not sure but your AC/Heating fan may not even be able to cool that much air so it will be a losing battle.
    Even if you don't heat/cool the basement (because it's temerature is moderated by the ground), then you will have to have at least a 5" Square opening to admit air without restricting the DC and you'll be sucking in cold or hot air from outside.
    The purpose of the DC is to prevent dust from getting into the room. If your DC is fitted correctly it will suck in dirty air and return clean air, why vent it outside?
    You should probably fit the grizzly with a canister upgrade, these have a cut point of 1-2 microns. Then you can put a plastic bag on the bottom for a much cleaner emptying process.
    • mikel
      • Jul 2006
      • 202
      • philadelphia
      • bt 3100
      Yup, the amount of air that would be leaving the space is a huge deal.
      I do forget how much air these things can move. What manufacturer would you look at for the canister?
      thanks...
      ...m
        this is the PSI canister, $169
        http://www.pennstateind.com/store/dcanister2.html
        and the bags you'll need
        http://www.pennstateind.com/store/dcpb740.html
        I got my bags from PSI
        but I got the Grizzly canister and I know that fits the HF DC fine (also can get from Amazon), $165
        http://www.grizzly.com/products/h5783
        Grizz has bags but $5 for one bag!
        http://www.grizzly.com/products/h6899
        The HF DC has a 20" ring which is standard.
        Jet also has a upgrade kit, http://www.amazon.com/Jet-708739K-DC...6?ie=UTF8&s=hi
        • wardprobst
          • 681
          • Wichita Falls, TX, USA.
          • Craftsman 22811
          You might look at:
          http://www.wynnenv.com/9e300bl_conversion.htm
          DP
          www.wardprobst.com
          • Sid
            • Apr 2004
            • 139
            • Bloomington, IL, USA.
            • Craftsman 22124
            Worse than losing cooled or heated air is the possibility of reversing flow in your furnace and water heater flue and sucking the carbon monoxide into your house--very dangerous!
            Sid
            • mikel
              • Jul 2006
              • 202
              • philadelphia
              • bt 3100
              thanks. I know to leave the windows open when using near gas devices. I'm looking at the kits now... thanks...
              ...mikel
              • pcombs
                • Aug 2006
                • 78
                Even with dust collection, some dust will end up in some other part of the house which could be a health hazard, especially if you have a forced central air system.
                Basement shops are not advisable, better to convert your garage, at least it is a totally different disconnected room from the rest of the house.
                My 2cents
                • mikel
                  • Jul 2006
                  • 202
                  • philadelphia
                  • bt 3100
                  Looks like just what I need. I will be getting the 35A filter kit today
                  http://www.wynnenv.com/35A_series_cartridge_kit.htm
                  I'll let you know how it works...
                  ...m
